Results 1 to 10 of 13
Thread: Corrosion, car stalling, can anyone name this part?
    Jan 2008
    Dartmouth, MA
    My car has been stalling randomly at stop lights or randomly when I put it in park. I found a lot of mice droppings under the hood, so now I'm checking everything under there and replacing some chewed up wires. I came across this part which is severely decayed and I'm wondering if it may be the source of the stalling... here are some pictures:
    My Nearly Complete Car:
    http://www.mp3car.com/vbulletin/show...ed-car-pc.html
    Micro Control Center... Control Your Car Across the Internet
    http://www.mp3car.com/fusion-brain/1...-internet.html
    Website: (It's a work in progress, really. All my projects have taken me from ever really developing it.)
    http://paulfurtado.com/
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    Looks like a vacuum line... and if you have a vacuum leak from a line having a hole chewed in it... it could certainly lead to a rough idle and stalling at idle. No clue what that could be for, or what it terminates in that cap, that's odd.
    RevFE
    My Shop
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    At a guess... vapor release valve? What does it come out of?
    TruckinMP3
    Read the FAQ!
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by malcom2073 View Post
    If it was a vacuum line, shouldn't it go somewhere from there instead of being terminated? Is it possible that there would be the option to have more than one vacuum line and this one is terminated? Rough idle and stalling is definitely what my issue is, so I'm going to have to look around some more. This gives me something else to look into.
    Quote Originally Posted by TruckinMP3 View Post
    It's coming out of the lower part of the engine as far as I can tell.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Quote Originally Posted by PaulF View Post
    Yea that looks like a vacuum line. Alot of times different models/features will require an extra vacuum line or one in a different place so they tap it and then cap it if its not used. Kinda the same way most cars have wiring for features even if they don't have them.
    Jan 2008
    Dartmouth, MA
    Quote Originally Posted by justchat_1 View Post
    Makes perfect sense. Seems obnoxious the way it is capped though. I'll see what I can find at autozone to replace it. Thanks.
    Mar 2006
    Montreal
    how old is the car, does it happen only when the engine is warm? check the engine wiring harness that goes from the module all the way to the crank sensor, my '98 bonneville did the same thing, due to canadian weather here, very hot and cold climates change frequently, causes the wires to deteriorate over time, also check your module, that may also be the culprit, my 2nd bonneville would cut out when it was warm, it would just crank and crank and crank even tho it has fuel, cooling it off it would start, but only for 30 minutes, check those 2, engine wiring harness and module.
    if you have cranking issues as well, due to the engine harness not being easily acessible, you'd have to unravel the tape to check the condition of the inner of the cables, usually the heat of the engine and outside temps can melt the wires over time, my first bonneville had the hardness melted in 2 different locations, one near crank sensor, and one near module, look for the fine print, MADE IN CHINA, lol j/k
    Aug 2009
    N. Virginia
    Looks like a vent on the transmission to me. If so, it won't be causing your stalling, but it should still be replaced to keep water and mice droppings out of your tranny.
    Newbie PCBum's Avatar
    Jun 2005
    Sunny California!
    Yep, vent hose
    "If at first you don't succeed, keep on suckin' till ya do succeed" (Stooges)
    Low Bitrate Salmizar's Avatar
    Oct 2007
    Ontario, Canada
    Your car is stalling and its not throwing a check engine light? I would check to make sure your check engine light works :P
    If it's stalling. The car should have caught it and stored a code. My guess would be a malfunctioning sensor.
  1. Replies: 334
    Last Post: 01-19-2011, 04:51 PM
  2. 2nd car battery
    By XMatrix in forum Power Supplies
    Last Post: 03-16-2010, 07:09 PM
  3. iPod-based Car PC
    By R3N3G4D3 in forum Newbie
    Last Post: 03-10-2009, 09:56 PM
  4. The planning part of my car pc is over!
    By HuseyinOzsut in forum General Hardware Discussion
    Last Post: 02-24-2008, 09:23 AM
