Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 1st Carpc to get stolen
    May 2007
    INDIA
    Angry 1st Carpc to get stolen
    I am starting a new thread about the security of the carpc itself. My carpc got stolen yesterday i.e. 12th December 2009.
    the thief broke my front passenger side window and took out the whole computer with the screen and all the usb device connected to it. So today i am planning to install a new carpc but i am thinking of adding some kind of security to it.
    would really like to know if any body has put any kind of security measure to stop the stealing of pc.
    Nov 2009
    Utilize some sort of laptop lock in a way to at least slow them down? Or perhaps mount things in the trunk out of sight, maybe consider using torx screws in an attempt at slowing them down?.
    Also consider just a better alarm system?
    You just have to remember that if someone wants to steal something, they are going to steal it.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You're not the first and you certainly won't be the last.
    Sucks I know, but there it is.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    I'm a fan of the weld it in method
    but seriously the best things you can do are make it less attractive to steal. Have a good and visible alarm system, make it look as OEM as possible, possibly even cover it, etc.
    Then of course there are the counter measures->everything from torx screws to connecting the screws to positive and hoping for the DIY taser effect--depending on how crazy you are.
    Variable Bitrate djvillar's Avatar
    Sep 2006
    New York, New York
    Quote Originally Posted by justchat_1 View Post
    ...DIY taser effect--depending on how crazy you are.
    That is awesome!!!
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    This is why I keep my carpc, amp, subs in the trunk locked. Only way to open the trunk is with a key since I disabled the switch to open the trunk from the inside. Also consider making a fake faceplate for your LCD as well as using a steering wheel lock as a visual deterrent. And if you are really hardcore, then you can start looking at alarm systems, surveillance systems, etc...
    No one single solution will keep you 100% safe, but every little thing that you can do to decrease your chances helps.
    Nov 2009
    DIY taser effect? sounds like a DIY fried carpc
    then again if its fried no sense in stealing it then
    Constant Bitrate simplex's Avatar
    Oct 2009
    Budapest, Hungary
    I will put the amp and the carPC under the seat, so the thief will have to remove the seats do steal it.
    I will add a some kind of mechanical protection for the screen, like some kind of shutters
    (or blinds, i dunno what is it in English) on it to look like the air duct grill, locked until I turn ignition on.
    Also, my car is very ugly and dirty from outside, so it's not even worth to look inside it
    Check my worklog:
    Corsa + Atom + Gentoo Linux + 9" capacitive touchscreen
    Lord of the boards: DFI CP100-NRM
    "Or you can try Ubuntu, but than don't tell everyone you are using linux,
    because it's just a secret unreleased prebeta of Windows 3829" :P
    Feb 2009
    this solution will 100 percent works. put a 12v to 220v inverter and stick shaved wires all around your stuff with glue and connect it to 220v. use a relay so when you turn off your car, relay turns on the inverter and all your shaved wires go live. then if anyone touch them, get shocked:d you might get flat battery but use less power inverters like 20watts or 50watts and you will be suit by the way stick some signs around your car to say that you got 220v, otherwise if you kill someone, you will get in trouble.... hahahaha but seriously if I had a expensive carPc, I would do that....
    There is nothing impossible in the world :-)
    Jun 2006
    Calgary, Alberta
    Blog Entries
    1
    Quote Originally Posted by shahabmusic View Post
    I dont know how well 220v will go through heavy clothing though? Ive had 120v go through two fingers before and that was SCARY.
    Although if you dont limit the current, you could kill them. Personally, I dont care about the well being of a thief, but here in Canada, you would probably get into serious **** for something like that. A better option would be to use the high voltage backlight inverter from an LCD. Probably like 600+ volts and the current is less.
  1. White Toyota corolla 2002 carpc
    By ravid in forum Show off your project
    Last Post: 12-02-2009, 06:10 AM
  2. My 1st CarPC in a 2001 BMW 325 Ci
    By BimmaDrew in forum Show off your project
    Last Post: 07-15-2007, 10:28 PM
  3. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  4. carpc with name brand monitor
    By fasteddie in forum Input Devices
    Last Post: 08-25-2006, 08:09 AM
  5. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 12:27 PM
