Results 1 to 10 of 16
Thread: Best way to keep the PC warm in the winter?
    Jun 2009
    Well winter is here and one thing i never figured was the cold being a factor. Well now that is dropping below freezing the PC will not start up. Any ideas what i can do to maybe keep it alittle warmer. I was thinking about wrapping it up but then it might over heat once it gets cracking
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
    Jan 2008
    trader007(i think thats the member name) found a small heating pad to use.
    usually it is the hdd that will not allow the system to boot because the fluid in the bearings will not allow it to spin up, so, from what i have read, most will let the computer start up, and after some time to worm up the drive, hard reboot the system so taht it can properly load...
    Jun 2009
    mine wont even boot untill it is running for a little bit
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    so far I haven't run into any issues
    though I've got a laptop that I keep in suspend mode, so there's a little 'heat' going through the board/drive
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    Jun 2009
    i am not sure if there is a senor or what. everything is solid state no moving parts
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    There is a guy in the forum who built a computer in the engine bay. Works if you turn on the computer after running the car for a bit.
    Jun 2009
    little up date on this. I moved the PC off the steel floor and to the top of the seat. seems that it turns on fine now. i am thinking there has to be some kind of switch controled by tempurature
    Nov 2008
    lol this is the 2nd "hottest" thread
    Yeh, sorry I couldn't contribute anything worth while
    Dec 2007
    Danville, CA
    Quote Originally Posted by RipplingHurst View Post
    Found it here:
    In the guy's signature there's a list of "cold weather mobo", you might want to check it out.
    Jun 2009
    that looks cool but for the way i drive it would get wet in the engine bay
