Results 1 to 10 of 12
Thread: my battery keeps dieing.
    Feb 2009
    so a couple months ago when i first got my truck i installed my carpc and then the battery crapped out so i went out and bought a new batter and everything was cool for a couple months until now. i let my truck sit for a few days over christmas break and when i went to go start it up it was completely dead. so i unhooked all power lines to my setup and jumped my truck and drove it like that for a couple days in hopes that it would charge back up. it all seemed good until yesterday when it died again with nothing hooked up except the negative and ignition wires to my m2. I had this exact same setup in my 92 acura legend and had no problems in there. Now i have an 03 ford ranger and it keeps eating batteries. the only thing i could think of is that my acura had a much better quality battery in there than my ranger.
    What should i unhook if i was to not start my truck for a few days so my battery doesnt die?
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Maybe your battery no longer holds charge after you drained it? I completely drained mine about 5 times before it would no longer hold a charge. When it did go, there wasn't really anything on (except my obdpro) that would drain it, it just died. Now I have a optima yellow-top and I must say, I really like it so far.
    If you take it down to an autozone or a les schwab, they can test out your battery and get you a new one.
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
    Feb 2009
    i was hoping thats not the problem considering the battery is only 2 months old. good thing i got it from sams club (they have no return policy)
    any suggestions as to what to unhook if im going to leave my truck sit for a few days? seems like just unhooked the amp and the power line to my m2 was not enough. unless the battery was already shot by the time i unhooked everything
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Quote Originally Posted by mm87 View Post
    If you've unhooked everything that would drain it and the battery is still dying, then I would question its ability to hold a charge.
    Dec 2008
    ford ranger alternators are the type that can have diodes go bad and you get no warnings. the truck will work fine if you start it everyday, but if you let it sit for a couple days the battery will be flat.
    its an easy test... if you unhook your positive cable to tbe battery (the big one/all of them), you can put an ampmeter between the battery and the cable, and youll probably notice its drawing around 1 amp.
    replacing your alternator is cheap and easy, so it might be worth a shot. again, even if you have the alternator tested they will say its charging fine... not everyone checks the diodes to make sure theyre solid though. i know all this cause my ranger ate batteries to no end for 6 months before i finally decided to replace the alternator. once that worked, i read up on my what actually happened and it makes sense now... just something you dont normally think about.
    Feb 2009
    thanks for that information.. but i dont think either my battery or my alternator are bad.. i think its just the fact that the m2 never completely stops drawing power and if it sits for more than a couple days the batter goes dead.. i removed everything and drove it for a few days like that with no problems.. so i think all is well
    FLAC Marvin Hlavac's Avatar
    May 2005
    That is a possibility. Especially if you live in a colder climate. Batteries tend to lose some of their capacity during cold temperatures.
    Laptop GPS World
    Jan 2008
    Now that you have made another post about the monitor power cable frying, I beleive that part of both issues is due to short, or poor connection somewhere. I would higly recommend you go over your entire install to make sure that it is not grounding out where it shouldn't.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    How much power does the M2 draw? Did you check it out with an ammeter?
    Want to:
    Constant Bitrate thewizard's Avatar
    Dec 2008
    Quote Originally Posted by soundman98 View Post
    I'll second this recommendation. Also as a side note, your monitor should not ever be able to draw anywhere near enough amperage to melt down the wire unless it is in fact shorted out somewhere, possibly even inside the monitor itself or if it were electronically damaged. That electrical smoke sure does stink though doesn't it? I have melted more than my share of voice coils back in my SPL days to know it all too well.
    Data911 M5 system
    RR and iGo8PC
    Pioneer head unit
    Pioneer DEQ-9200 digital processor
    Phoenix gold line drivers
    Ultimate and Visonik amplifiers
    SMT 3 way active front stage
    Digital Design sub woofers
    3 runs of 0 gauge wire
  1. Measuring Initial Car Battery Voltage Help Needed
    By pblakeney in forum General Hardware Discussion
    Last Post: 11-11-2010, 09:37 PM
  2. 2nd car battery
    By XMatrix in forum Power Supplies
    Last Post: 03-16-2010, 07:09 PM
  3. Battery Dieing?
    By Tosi in forum Power Supplies
    Last Post: 01-26-2007, 10:48 AM
  4. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
  5. time to a dead car battery?
    By chuckctv in forum Newbie
    Last Post: 08-20-2004, 11:08 PM
Tags for this Thread
