Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: rfid keyless ignition
  1. #31
    Aug 2010
    I've sent a pm and would also like to get a step by step for this, E-mail in pm. Great job man.
  2. #32
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by jayrod7387 View Post
    the main components are
    2 - dei 611t relays(ebay $20/each)
    1 - set of relays (like the ones that come with a remote start system or one relay for acc, one for ign1 and so on)
    1 - ordinary (momentary) push button.
    Basically the dei relays can be used as either latched relay or timed relay(0-100 seconds) and they are activated by either - or + pulse.(from the push button) i used one as latched and one as timed. They are both activated by the push button. the timed output can be adjusted for a suitable crank time for your vehicle. You will want to have the output going to a relay, not directly to the start wire. the other dei relay is set to turn on a set of relays that keep constant power to acc. ign1 ign2....etc so it will turn the acc ign on and send a timed pulse to the starter all with a push of a button. ****one thing you will want to do is put a NC relay in line of the pulse activation wire that runs from the button to the timed ouput relay. It should open(break) the contacts when its recieving a + signal from the latched relay. (this is very important it prevents the starter from engaging when you push the button to shutdown the engine.
    Howd did you get around the transponder on the ECU? did you have to insta;ll a bypass module or did you just install one of the modules that holds a key?
  3. #33
    Low Bitrate sk8rjess's Avatar
    Nov 2007
    i know this is almost a dead thread, but i've installed a system for a customer called the st800 by auto innovatio.
    it sounds to me like that would work for ya. i love the system.. once i decide to do power locks on my truck, i'll end up installing one in it.
    http://www.auto-innovatio.com/
    they call me hack
    Independence Auto Tech
    http://ctxdesigns.com - web design :)
    "Let us search out and examine out ways, and turn back to the Lord; Let us lift our hearts and hands to God in heaven." - lamentations 3:40-41
  4. #34
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    look up digital guard dog...
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
  5. #35
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by sk8rjess View Post
    i was actually looking at this the other day and seriously considering purchasing the DW-Tech touch start button. My only problem is i dunno where i'm gonna put the button in my crammed RSX cabin lol
    Live mp3Car Facebook Chat
  6. #36
    Nov 2007
    ah dude PM me. i'll get you some pics of what we did for him. i ended up making a place for the button to sit and look OEM. rather than sit on the steering wheel where it can't be seen.
    EDIT: and ironically enough, he has a 2004 rsx as well
    they call me hack
  7. #37
    Apr 2011
    I'm new on this forum for my new project.
    But this was my previous project
    Click on it for video. Same as advancedkeys.com, but than alot cheaper without a logo. Orderd on aliexpress.com.
  1. ignition wire
    By TeamRSX in forum Car Audio
    Last Post: 05-16-2008, 10:53 AM
  2. Ignition Switch Details?
    By brianafischer in forum General Hardware Discussion
    Last Post: 09-23-2006, 10:31 AM
  3. In search of an ignition wire
    By witten in forum Power Supplies
    Last Post: 07-27-2006, 02:29 AM
  4. Ignition and Button on/off power
    By TurboTronix in forum Power Supplies
    Last Post: 04-25-2005, 01:02 PM
