Results 1 to 3 of 3
Thread: Engine noise only with sirius on
    Jun 2009
    I had this issue with the EEE PC i was using and now with the one i built. I moved the MJS unit away from power but the sirius unit itself is still near the Carnetix 2140 unit. if i go to music i do not get any noise and with the amp just on it has no noise. any ideas what is causing it. I am leaning towards the 3.5mm plugs.
    2009 Volkswagon Tiguan
    Custom Built Carpc, Only way to go
    Jan 2008
    engine noise is usually caused by ground loops-- either bad grounding connection, or with devices that are connected together, but powered, and grounded to different physical points in the car. you can try changing the location that the unit is powered to the same loaction as the other items, otherwise, try moving it away from the power supply.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I get some ground loop noise from my ALP1. It sounds a hell of a lot better if it's connected with an optical cable.
  1. Engine Noise in speakers
    By OpIvy in forum Car Audio
    Last Post: 09-25-2008, 11:12 AM
  2. Noise from my audio only when engine is ON
    By FX35 in forum Car Audio
    Last Post: 03-17-2008, 06:57 PM
  3. Nasty engine noise
    By kickercivic1 in forum General Hardware Discussion
    Last Post: 02-07-2008, 01:54 PM
  4. Sirius PCR ?
    By Retsaoc in forum General Hardware Discussion
    Last Post: 03-15-2005, 04:55 PM
  5. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 11:47 AM
