Results 11 to 20 of 30
Thread: Has anyone ever had a good sounding carputer yet?
  1. #11
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    Is the noise your hearing from the hard drive or the alternator (does it change when you rev the engine)?
    Most likely its a floating ground on the PC power supply side since theres no ground filtering between the 5v bus and the usb hub on most mobos. What power supply did you go with?
  2. #12
    Maximum Bitrate pcpete's Avatar
    Mar 2008
    Toronto Canada
    I've got a Carnetix P2140...when I had the fszfsz sounds from my tweeters it did seem to escalate with the HD spinning....it also mostly/completely went away when i stoped powering my xenarc from the Carnetix..
    It definately wasn't from alternator as it was still there when engine was off...
    it wasn't from audio signal as it was still there when i unplugged the rca (symbilink in my case) cables...
    what really made it go away was when i powered off my xenarc...so I rewired it to get power from my cig adapter and it is good now...
    the hd would also introduce some static when it got busy...I screwed the motherboard on a metal plate and grounded that real good...almost can't tell the diff now from when my amp is powered on or off...
  3. #13
    Jan 2008
    Just a note on monster rcas- compared to lower end cables, they are junk. All of monsters recent RCA cable offerings use twisted pair constuction, which would work fine in balanced audio setups(twisted pair simply subjects the noise to both pairs of the cable, which should in theory cancel it out). Most audio equipment doesn't have it though.
    IMO, the best cables in any price range are home theater grade cables that have a negative shield surrounding a center positive wire- these shield the most important part of the signal.
    Ok, I will go on for a little longer... I tried a x-fi for a little while and also had turn on popping and driver issues with it, so it got scrapped in favor of a differently branded card(esi gigaporthd) that I do not have any of the same issues with.
    Sometimes you will need to put some money into audio cards that fit your install. I went through 3 trying to find the best one for me.
  4. #14
    Mar 2008
    Quote Originally Posted by justchat_1 View Post
    I got the D945GCLF2 motherboard with a M2-ATX PS. Would you just run a ground to the case from a negative pin on the USB or from a ground wire directly form the power supply?
  5. #15
    Mar 2008
    Quote Originally Posted by soundman98 View Post
    You think I should give that sound card a try? I will check new egg right now and give it a shot. I also have a bunch of high end home audio RCAs I will try out too. Thanks for the advice.
  6. #16
    Variable Bitrate Deric's Avatar
    Sep 2006
    I'm using the on-board sound with the CLF2 in a 4 channel setup and have had zero issues. The sound is as good if not better than the head unit it replaced.
    Quote Originally Posted by tech180 View Post
  7. #17
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    i just have to say i get good sound with no engine noise even on basic test wire that is twisted in 20 spots and running all over and around the car. The only time i had an issue with sound was when i was using an inverter... Naturally.
    Otherwise never had an issue and this is with onboard and external cards? Then again i have a lot of luck with electricity ... i should be dead at lest 10 times over...
    2004 Holden WL Caprice Auto GENIII
    Base System = Raspberry Pi
    Everything else is pending for now as switched from a Mini-ITX setup
  8. #18
    Mar 2008
    Adelaide, Australia
    by twisted i mean exposed multi-joined wire and more. As for the quality... it has been better then 99% of head units i have used.
  9. #19
    Constant Bitrate Startingline13's Avatar
    Nov 2007
    Long Island, NY
    I use the Alpine H-701 sound processor and RUX controller with my car PC. Enough said.
  10. #20
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    You missed the important question....does the noise change when you rev the engine?
  1. Carpc or Carputer Complete Guide
    By smhussain in forum Newbie
    Last Post: 04-21-2009, 06:58 AM
  2. mazda 3i aftermarket carputer. this any good?
    By StUpId8000 in forum General MP3Car Discussion
    Last Post: 01-25-2009, 05:36 PM
  3. My carputer is dead, please help me before I drop this project for good :(
    By GibsonLP in forum General Hardware Discussion
    Last Post: 05-13-2007, 12:08 PM
  4. Replies: 8
    Last Post: 02-18-2007, 10:20 PM
  5. good carputer mobo (other than price)?
    By BullCreek in forum General Hardware Discussion
    Last Post: 01-20-2005, 05:26 PM
