Results 1 to 6 of 6
Thread: Pc power button questions
    May 2009
    Hello, I would like to run around a 12 foot power button cable... will this carry enough current to turn the PC on? i don't want the computer starting off ignition for when i am just moving the computer short distances i rather have a power button in the front of the car from the trunk...
    any suggestions... also where i can pick up such a cable? as online all i have found is 12 inch extensions.
    email is [email protected]
    Variable Bitrate UnusuallyGenius's Avatar
    Mar 2009
    Grand Rapids, Mi
    make one yourself, best route to go
    - Project: Unified Car Control
    - Original OpenMobile Interface Designer
    May 2009
    what gauge cable? and where to find the little ends. to connect to motherboard
    Elsewhere
    You can use just about any wire.
    I used Cat5 to extend power & reset buttons and LEDs to the front of my truck. Works like a charm, although it's less than half the length of your run.
    You can get the jumper leads at any electronics store.
    Or try Mouser, Digikey or Jameco. They all have what you want.
    Another option is to take the entire power button assembly, with the lead and cut the wire. Splice in your own length of wire with solder & heatshrink.
    Away you go!
    How about the Wiki?
    May 2009
    thanks for the info.. i think i will use some cat 5 so the cable is protected some... now i just need to mount the beast.. but i may do a mobo upgrade before i do.
    Maximum Bitrate Crinos's Avatar
    Mar 2009
    Kristiansand, Norway
    On a Cat5 cable, you should be good with your 12feet strech.
    Ultra low voltage have about 5 meters of reach before it looses power.
    12 feet is about 3.5 meters.
  1. Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail!
    By hd54321 in forum Power Supplies
    Last Post: 02-24-2005, 12:42 PM
