Results 1 to 2 of 2
Thread: wiring help needed
    esa is offline
    Feb 2010
    wiring help needed
    I am trying to wire a boot popper kit to my car with a slight twist I want to be able to pop the boot either from pressing the button that is mounted in the dash or the button that will go where the rear wiper used to be. I will be using the rear wiper motor as my power supply. My questions are the following,
    Can I use two power sauces ( i need to be able to press either switch and it should open the boot) going into pin 86 if not what options have I got?
    Is it ok to wire one device to more than one relay ? ie the boot popper slenoid because if it is then I suppose I could use two relays and that should work.
    Dec 2009
    Yep it is correct, just put the buttons or switches in parallel and you will be fine. It's called a "OR", "AND" would be multiple push-buttons in series.
  1. Replies: 8
    Last Post: 02-14-2006, 06:43 PM
  2. if you designed a vehicle's interior and wiring, how would you do it?
    By stapan in forum General MP3Car Discussion
    Last Post: 12-26-2005, 01:56 PM
  3. Replies: 8
    Last Post: 10-17-2004, 11:59 PM
  4. Wiring Help Needed Please
    By tbird2340 in forum Newbie
    Last Post: 08-31-2004, 12:02 AM
  5. wiring help needed! :)
    By bulgogi777 in forum Power Supplies
    Last Post: 08-06-2004, 03:50 PM
