Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Holden WL / VZ Caprice GENIII LS1 - Slow Build Follow - Some Tech Info
  1. #11
    Newbie trigge's Avatar
    Mar 2006
    mayhem,
    I have a carputer installed in a 2001 Commodore S, if you require any info or want to know problems I have found with installing in a Holden feel free to drop me a line. Keep posting pics with updates, you might give me ideas for change in mine..
    Regards,
    Scott
  2. #12
    Variable Bitrate mayhembdm666's Avatar
    Mar 2008
    Adelaide, Australia
    Hey trigge,
    I think the main thing i want to find out or just confirm are the pins on the ecu connector under the steering wheel. I need to double check but from what i remember hearing is it that it still talks the ALDL stream but using a obdII socket/plug
    I really am hoping it is OBD2, But thinking about the update speed of the trip computer says otherwise.
    2004 Holden WL Caprice Auto GENIII
    Base PC = Installed
    Front End = In Progress 75%
    OBD2 Interface = Installed / V2 Due Soon
    Realworld Interfaces = In Progress 20%
    Internet Linking = In Progress 10%
    Voice Control = In Progress 35%
  3. #13
    Mar 2006
    Mayhem,
    You need to investigate further for the protocol that the ECU talks as there was a changeover period for the commodores from ALDL to OBDII very close to your year model car. Also there may be different changeovers depending on V6 or V8 as well.
    I started to get into the ECU display feature of Ride Runner but halted that when I moved to NT. From my experience it was easier to get a pre made plug and find the software.
    Hope you figure out the ECU protocol as it would be good info to put on the screen.
    Regards,
    Trigge
  4. #14
    Mar 2008
    Adelaide, Australia
    The one and only part I have never liked about a CarPC is the removing the head unit unless something slots perfectly in place of it, In saying that "Now" the replacement fascia is available in the shop.... But lets see what i can do with this one for now...
    The current setup is with the Screen hacked and packed into the original radio bracket with a little help from plastic putty, Room will be made for a replacement IR Receiver and possibly a power button depending if I try to automate the IR/Buttons on the Touchscreen itself.
    Original Blaupunkt Stereo / Pinout
    Replacement Items
    Base PC = Installed
  5. #15
    Mar 2008
    Adelaide, Australia
    Holden GENIII V8 Serial UART Information
    Just adding this post for future reference in the way of the serial connection side of things.
    Base PC = Installed
  6. #16
    Mar 2008
    Adelaide, Australia
    Arduino / Blaupunkt 679 Stereo UART Connection
    Okay so for the fun of it, I decided to start playing around with the original stereo (Blaupunkt 679 / 6 Stacker) as i figured this might be one path to check for being able to set the time on the top centre LCD which shows items like the air con and so on.. And the amount of people who keep telling me the time is wrong is starting to drive me nuts. So.... See if i can read the commands from the head-unit and then send them back to the car itself...
    At the moment I'm just reading the head-unit itself and seeing what is what... but its fairly hard to tell without a display and will be a day or two before I bother with trying the UART connection in the car.
    Using this sketch:
    Code:
    #include <SoftwareSerial.h>
    SoftwareSerial mySerial(2, 3);         //rxPin, txPin  (Only used rxPin with common ground)
    void setup() {
        Serial.begin(4800);
        mySerial.begin(4800);
    void loop() {
        if (mySerial.available()) {
            Serial.println(mySerial.read());
    So anyway this is something that I figured might help with quickly adapting old functions from head-units or may time directly into general commands that will be used.. ? Now just to get the 8192 side of it
    Base PC = Installed
  7. #17
    Mar 2008
    Adelaide, Australia
    Arduino / Prototype Board
    This section will be to follow the design and circuit(s) used on a prototype board for the Arduino which in most part will be the main shield design.. Allowing for quick and easy replacement of a dead Arduino during testing...Hmmm pricey when the wrong wire touches..
    Current Circuits on Shield Design:
    * Monitor Buttons
    * Steering Wheel Controls
    * TV Output using (arudino tvout)
    * IR Receiver for Remotes
    ** Forgive the messy work, Like i said... Testing stages on most things..
    Base PC = Installed
  8. #18
    Oct 2011
    I like it! Nice and clean...
    What kind of speakers and configuration are you planning on in the final audio 5.1 setup?
  1. Replies: 19
    Last Post: 10-26-2005, 11:53 PM
  2. Real Time Car tracking now working!
    By Magpie in forum GPS
    Last Post: 10-27-2004, 04:08 AM
