Results 1 to 10 of 11
Thread: Fusion Brain digital output for HVAC.
    Maximum Bitrate stonestatue's Avatar
    Feb 2006
    Huntsville, AL (Atlanta, GA temporarily)
    I'm in the process of installing the car PC in my van and want to incorporate HVAC control into it. It has the Fusion Brain 4.0 which has 16 digital outputs and 13 analog inputs. I have already done some analysis of the situation in this thread:
    http://www.mp3car.com/vbulletin/gene...mc-savana.html
    I realized the Fusion Brain's digital outputs are not variable. It's either 0 volts (off) or 5 volts (on). That's good for turning on and off switches, but I want to control the temperature. This is done via a servo motor which opens a flap to determine how much heat to let in. The servo is controlled by a controller. The controller determines how far the temperature blend door is open based on a signal from the temperature dial. The temperature dial acts like a rheostat or potentiometer and has 21 different inputs it can send to the controller.
    I determined that it is a variable resistor logic input. This means that it starts out with zero resistance and goes up to full resistance. I'm not yet sure which one is full open and which one is full closed, but that won't be hard to figure out.
    All that being said, I would need the Fusion Brain to output a signal of varying resistance (21 "buttons" in Road Runner) to mimic the temperature dial. Since the digital outputs can only be on and off, it can't vary the voltage. I did notice that it has PWM capability, however I'm not sure if that can help me achieve my goal. Any help is greatly appreciated. (Greenman perhaps?)
    Check out my GMC Savana worklog.
    Remaining tasks to facilitate vanputer installation codename "Enterprise":
    - Edit skin to liking.
    - Get compatible phone for mobilephone.net.
    - Facilitate HVAC control.
    VegasGuy's Avatar
    May 2009
    Las Vegas
    Quote Originally Posted by stonestatue View Post
    Where you get in trouble is trying to run inductive loads (motors, servos, incandescent lights) off the digital ports. Your probably going to need some additional circuitry and hardware between your fusion brain and the systems you want to control.
    Do a search, because there are people that have done it on this board. You might want to check out RelayPros.com for some more robust controller options. Good luck!
    VegasGuy
    Fusion Brain Creator
    Mar 2005
    you need a digital pot. look them up. you want the "pushbutton" type, then emulate pushbuttons with digital outputs.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Can you replace the servo with a standard R/C servo? They use PWM to control position.
    Want to:
    Feb 2006
    I am not sure how easy it would be to fit.
    Feb 2006
    Regarding the digital potentiometer, how exactly would that work?
    Sep 2005
    Australia
    Why not having a look at the eyeR interceptor pro. It has many dedicated HVAC features and also a back up custom infrared remote for when you PC hasn't booted up yet or fails. Though if you already have a fusion brain, and like the idea of a dedicated HVAC remote you can now buy the remotes seperately. It's has intergrated servo and PWM control.. Just a thought.
    Feb 2006
    It looks interesting, but can it emulate variable voltage outputs?
    Feb 2006
    Quote Originally Posted by greenman100 View Post
    Could I use one digital potentiometer that outputs different voltage levels or would I need one digital potentiometer for each dial setting (21)?
    Jan 2010
    Can you hook up an RC/PWM type servo to the mechanical Temperature dial? System would be something like this.
    Front end > FusionBrain > PWM Servo > Temperature dial > Controller > OEM Servo
