Results 1 to 10 of 14
Thread: could my ssd be too fast?
    Apr 2009
    Newark, New Jersey, United States
    I have a silghtly annoying issue with my carpc.
    quick run down of what i'm running : 1x 32gb vertex ssd, 1x 500gb WD platter drive.
    2.2ghz amd process (single core sempron) some gigabyte mother board, cant remember the name. 2gb of ram.
    issue : upon resume from hibernation (win7 ultimate) and the music begins to resume from winamp, it begins to freeze for 1-2 secs every couple of random secs. then after 1-2mins the song continues to play without any hiccups.
    I have 180gb of music loaded into a playlist in winamp.
    at the time of resume, the only app running is winamp.
    if i set the machine to shutdown instead of sleep/hibernate upon leaving the car, there isnt any issue.
    i turned off cpu processor throttling ... so the pc should be running @ full power at all times.
    Can any suggest anything??
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    don't hibernate?
    I don't know, something about freezing things (processes) instantly and then thawing them out instantly a while later seems like a bad idea. I stopped hibernating/suspending my system because of the weirdnesses that comes with hibernate/suspend. There isn't a noticeable boot time difference between cold and resume anyway on my system with the vertex SSD.
    I doubt it has anything to do with your ssd and has everything to do with hibernate/resume voodoo.
    Former author of LinuxICE, nghost.
    Current author of nobdy.
    Oct 2006
    usb sound card? or onboard? or...?
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    is the hib file on the ssd or the wd drive? Audio stutter is caused by a buffer underrun. If it was anything else (like driver related) it wouldn't keep occurring.
    Also, do you have anything that runs on hibernation resume?
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    It could be the SSD, or could be an anti-virus scanning, or WiFi redetecting routers, or anything else. What's using the most CPU on the task manager during that time?
    Low Bitrate SenatorIvy's Avatar
    Sep 2007
    Detroit
    How is your platter drive hooked up? Is it SATA/USB/eSATA?
    When I had a sata drive hooked up via an external enclosure, my carPC would do this and things similar to it when it resumed, because it was trying to play its memory's buffer of the song, and the drive had yet to be activated to read in the next bit. After a minute or two the external drive would spin up and things would resume.
    I eventually just put the drive straight to the board and this problem went away. 2 years now with a WD500 and it has yet to rattle itself apart. :v
    Apr 2009
    1. onboard sound card.
    2. i would take a wild guess and say that the hib file is on the ssd.
    at the time if hibernate/resume , winamp is the only program running
    3. not antii virus, no wifi . i have not checked whats running via the task manager while resuming. i will try that tomorrow!
    4. the platter is hooked up via sata.
    Oct 2006
    try a different front end and see if the problem persist. i recommend freeice, its nice and light and easy to install.
    Apr 2009
    i went back to centrafuse.
    did some tests lastnight. i haven't gotten the issue yet.
    i will continue to test.
    i normally reserve centrafuse for when guests use my car, its easy.
    just not for me, it does not excell at massive amounts of media.
    Mar 2004
    Florence Yall, BFKY
    Quote Originally Posted by Punky View Post
    Good idea. Even something like WMP or winamp. Start playing anything, hibernate and resume. If it has no issue, then your FE is the problem.
  1. little confused about ssd decision. need advice
    By luna123black in forum General Hardware Discussion
    Last Post: 02-25-2010, 06:59 PM
  2. Replies: 6
    Last Post: 12-30-2009, 08:46 AM
  3. Everything you need to know about Solid State Disks (SSD)
    By ioi8 in forum General Hardware Discussion
    Last Post: 08-31-2009, 12:46 PM
  4. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 11:19 AM
