Results 1 to 7 of 7
Thread: Issues with SSDs and XP for car PCs?
    Constant Bitrate rotarypower101's Avatar
    Oct 2004
    Portland/MtHood Oregon
    Hey, I am thinking about getting a SSD drive and want to know what are the issues specifically for a car PC and windows XP.
    I have read a couple conflicting compatibility tweaks that should be done, and wanted to get a good feel for what is required before purchasing.
    I use hibernation, and this is one of the things in particular, I don't think I could do without, unless the boot times are just that fast, that others consider this a non issue?
    Is it recommended by those that know that vista be used over XP for built in compatibility, or is XP %100 OK with no issues to use under the correct/proper changes?
    Also been reading about tangible speed and feel between brands, can someone comment on which would be optimal for a carPC?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    I have a Patriot 32GB that I use to run XP off of and I have not compatibility issues with it.
    Raw Wave
    justchat_1's Avatar
    Jul 2008
    Boston, Ma or NY,NY
    its not a compatibility issue as much as a longevity issue. Vista/win7 were designed to be used with ssd's and make several internal changes when running from them to increase performance and increase the life of the drive. As you may/may not know, SSDs have a limit to how many times sectors can be written to before they stop holding new data. Thats the basis for the concerns and a lot of the tweaks.
    Low Bitrate mnwcsult's Avatar
    Mar 2007
    Maryland, USA
    SSD Ok
    I am using this
    It is labeled Dana Electric 80 GB SSD and is a repackaged intel drive. Damn fast.
    I running XP performance edition. Boots incredibly fast. No problems.
    Raw Wave
    Nov 2009
    Quote Originally Posted by justchat_1 View Post
    SSDs have a limit to how many times sectors can be written to before they stop holding new data...
    So it's similar to memory sticks (USB keys etc)...
    (Especially running applications of a stick - ie, tweaking for more PC buffering for least write cycles.)
    And here I was assuming they were using some static or normal RAM....
    Thanks justchat - that's a very important consideration when I get an SSD. (That's one less unknown unknown for me - now it's a known unknown.)
    Newbie SGAsgard's Avatar
    Sep 2009
    Terrebonne, QC, Canada
    here a link that may help you understand why vista/7 a better for longevity than xp for ssd
    Jun 2007
    St. Louis
    If you're concerned about "longevity" or "performance" of the drive when running XP check out running XP with either EWF or FBWF.
    I run XP Pro w/EWF and it boots wicked fast. From power on to front-end is around 17 seconds. If you remove POST time from the picture XP loads in about 7-9 seconds.
    If you're not set on XP, Windows 7 is the next best thing. I ran it for a couple months and had pretty good luck with it, but had better luck with XP. Might have been driver related though for my issues.
