Results 1 to 10 of 15
Thread: Ok so, 'Build your own car pc'...
    Apr 2010
    Wink Ok so, 'Build your own car pc'...
    I've recently brought the 'Build Your Own Car PC' book from author Gavin D.J. Harper, and I've got a few questions about the equipment that he has suggested/selected for his book.
    Firstly, the Griffin RadioShark.
    - I've recently read a poll where only 1.88% of people used a Griffin RadioShark with they're setup, this poll was heavily won by Directed / Visteon HD Radio which was 43.19%.
    Is the Directed / Visteon HD Radio CarPc easy? Does it come highly recommended? I saw a photo of the setup and it looked like the Visteon had a separate head unit, is this correct?
    Secondly, the Andrea Auto Array
    - This component is a voice recognition microphone for the CarPc, in the book Gavin has listed a table with a list of statistics proving the Andrea unit to be a clear winner. Is this the case? He only lists 'Compared Microphones' as apposed to saying which he compared to.
    Thirdly, the Hitachi Endurastar 30gb Hard Disk
    - Gavin recommends this for a HDD, he states that the Endurastar is very resistant to shocks and average car use, Would an SSD be a better option? Money aside, the Endurastar doesn't really have any perks against an SSD.
    If someone could answer any of these questions or clear up any cloudy areas for me that would be awesome!
    Thanks guys
    May 2006
    Calgary, Alberta
    For the hard drives a solid state is better for durability and speed but my $60 2.5 inch laptop drive has been working fine for years.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Jan 2008
    a quick check, and i found that th book was published back in '06...
    so some of the info isn't very accurate anymore..
    i don't use radio, but the directed/visteon units are the most popular since mitches cable started getting made to control them(probably about 06-07 when that came out)
    they do have a external controller unit, but i don't think that you need it to allow the computer to control it-- just mitches cable, and a aux input..
    the andrea is still one of the more popular ones, though it has taken a little different form:
    http://store.mp3car.com/Andrea_Super..._p/com-054.htm
    the reason for this is because the included usb dongle has echo, and noise cancelation in it-- so that if you make a phone call, the usb dongle will make the audio clear enough that the person on the other end will have a hard time knowing your in a car..
    a normal mic(without echo/noise cancelation) will pick up EVERYTHING-- from road noise, to the police sirens behind you , and will make it much harder for the other person to hear you..
    for the hdd: there was a huge debate on types of hard drives in the environmental section. overall, it depends on how much you want to spend:
    some users use 3.5" home computer drives-- some of these have survived multiple car-totaling wrecks.
    2.5" laptop drives are popular because they are cheap, have lots of storage, and small, and because they are smaller and lighter, physics, and the laws of motion say that they are less prone to vibration damage then 3.5" drives...
    ssd is seems to be 'almost' the best, but cost-per-gb is kind of high, and the limited write cycles are also a disadvantage, but they can theoretically survive anything a normal 2.5" drive wouldn't, and are not affected by cold as much.
    overall, 3.5" drives are worse then 2.5", and 2.5" is worse then ssd, but none are perfect.
    then there are the platter speeds-- a 5400rpm drive is noticeably slower booting, and accessing info then a 7200rpm drive... if you are not keen to the cost of ssd, get a 2.5" 7200rpm drive-- it is worth it over 5400rpm..
    in planning, i would recommend buying 2 drives of identical size, and keeping one as a backup with all the same files on it.
    i used to be religious about this, then i updated to win7, didn't have a chance to update my back up drive, and 2 days after finishing the update, my primary drive took a dump...
    the other major change that i think the book is going to miss is the large amount of dc-dc power supplies, and the tiny atom powered boards that are hitting the market like a tidal wave-- they make great, cheap car computers that can do carputer duty beautifully for most carpc-ers
    another good place to look for some other info is here:
    http://www.mp3car.com/vbulletin/advfaq.php
    Apr 2010
    SOUND MAN THANK YOU SO MUCH!!
    Your info is so valuable thanks heaps!
    Apr 2010
    I'll go with 7200rpm SSD by the way.
    Jan 2008
    Quote Originally Posted by skooki View Post
    do you mean a high speed ssd? because there is no moving parts in ssd's, they are usually measured using their read/write speeds
    otherwise, i have been using a 7200 2.5" drive in my own setup-- nothing to break any records, but works for me-- win7 takes something like 2-3 min to get music playing (estimate: never actually timed it yet)
    Mar 2010
    Talking
    If you put one in an industrial blender, it might do 7200rpm...
    Jan 2008
    apparently, it is the about only thing that blendtec hasn't tried yet...
    May 2006
    Calgary, Alberta
    Quote Originally Posted by soundman98 View Post
    Ha, I looked there as well! Looks like they only do full closed systems and not individual parts.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Apr 2010
    haha yes i meant high speed but SSD mainly interests me because of boot time? Apparently a lot faster than your average 2.5'' drive
  1. FAQ: Why not Home PC speakers for the car?
    By RedGTiVR6 in forum The FAQ Emporium
    Last Post: 03-08-2010, 08:44 PM
  2. Replies: 4
    Last Post: 08-28-2006, 09:30 PM
Tags for this Thread
