Results 1 to 4 of 4
Thread: Centrafuse 3 Audio loop problem???
    May 2009
    Hi there. I have been using Centrafuse for not quite 12months now without too many issues. I now have a problem with playback of music audio files. Button clicks play fine until I go to play a song, then It starts looping approx the first 1/2 a second of the song, after this the button clicks also start looping. Only stops looping after exiting Centrafuse
    Was happening in Centrafuse 2 and so I decided to install the trial of Centrafuse 3 and was running fine for a little while but has now also started doing exactly the same thing.
    The only thing I can add was that I installed Google Earth Pro (GPS support) and I think it may have started at around the same time as I did this. I have since uninstalled Google earth but the problem has remained.
    Can anyone shed some light??
    I should add that the same files play fine from windows media player
    regards Bikie
    Jan 2008
    maybe the centrafuse forums would have some better ideas? being that you paid for the program, they should be very willing to give you support..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    May 2009
    Quote Originally Posted by soundman98 View Post
    I have already posted this exact same thread on the centrafuse forum. I just thought being that mp3car has a much larger user member database I would be more likely to come across someone that has had a similar problem. At this stage I am not sure if it is centrafuse specific, could be something to do with google earth
    cheers Andrew
    May 2009
    I have had a chance to do some more testing today... It seems this problem is only occuring with MP3's. Videos seem to play fine in centrafuse. It makes no difference if the MP3 is on a usb stick or on the EEEpc hdd. I should add that in 2.2 navigation directions and all audible clicks all play fine.
  1. Centrafuse 2.0 Final
    By Jan_RedGTiVR6 in forum Centrafuse
    Last Post: 08-17-2008, 12:35 PM
  2. audio problem
    By tiburonputer in forum General Hardware Discussion
    Last Post: 08-11-2005, 03:58 PM
  3. I tried everything, can't get rid of this ground loop
    By intense in forum General Hardware Discussion
    Last Post: 07-10-2005, 08:58 AM
  4. MP3 Problem in Centrafuse
    By vwpc in forum Centrafuse
    Last Post: 04-14-2005, 11:50 AM
  5. Complicated Audio Quality Problem
    By StangBoyCIC in forum General Hardware Discussion
    Last Post: 12-17-2003, 03:05 PM
