Check for rubber plugs that can be drilled and reinstalled. My truck is available w/ a std trans so there is a foil patch (used to be plug on my older trucks) where the clutch pedal rod went through.
This worked perfect for running wires in. I doubt a std trans was available in a Crown Vic but being that they were used alot for police cruisers, it wouldn't suprise be that some provisions are there from the factory to run wires inside.
LinkBack URL
About LinkBacks
