Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Help! My XP disc is damanged
  1. #11
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    If you cant DODGE em, RAM em.
  2. #12
    Jul 2009
    Melbourne Australia
    G'day Ram.
    Download and install this small utility that scans your HDD and locates and displays the product keys for XP & Offise etc.
    Just copy and paste to a fresh install of XP. if you can get a XP disk.
    http://www.nirsoft.net/utils/product_cd_key_viewer.html
    Just tried this util, Shows key for XP, Office & IE.
    Good luck
    Barry
  3. #13
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Quote Originally Posted by niss42 View Post
    G'day Ram.
    Good luck
    Barry
    If you would have read through the entire thread, you would know that his machine isn't booting into windows, making this utility useless.
    Tidder
    Try RevFE
  4. #14
    Jul 2009
    Melbourne Australia
    Must feel good to be a green arse wiper.
    Re- read your own post No 8
    Yer a mod! alright.
    niss42
  5. #15
    Sep 2003
    New Mexico, USA
    I did, but I'm still not sure how the utility you linked to will help the OP? If he can't boot to windows, how will he run the utility?
    Collect your thoughts, try again.
    Tidder
    Try RevFE
  6. #16
    Feb 2007
    Motor City
    lol, would i be able to see the contents of the drive if i slaved in another one? Most of the music on the drive had been backed up to an external drive, but it was the painstakingly addition of the tags and cover art that was added to the drive after the transfer from the ext. one that i didnt back up. Not to mention the videos and extra music from the thumb drive.
    Food for thought......always back up your files.
  7. #17
    Jan 2008
    in most cases, you should be able to recover it that way--as long as it is just the OS files that have the problem..
    if the hdd is starting to go, the bad sectors could mess with your other data as well..
  8. #18
    Dec 2009
    Bozeman, MT
    Tidder edit: Warez talk isn't allowed here.
  9. #19
    Jan 2011
    If you still need I can make a copy for you of an XP Pro or Home CD. Mind you this does not include a license, you will have to use your own which should be on a sticker on your PC or retail box.
  10. #20
    Constant Bitrate cla1067's Avatar
    Apr 2009
    Sarasota, FL
    I can't remember if partition wizard bootable cd can do it or not, but if your have information that you need off your drive I can give you a couple of solutions.
    bootable partition manager: Partition wizard bootable (download) or Ultimate Boot Cd
    A live cd of an Operating System like Ubuntu or Windows XP which will allow you to run another operating system off of a cd which would let you have access to your c drive.
    or probably the easiest thing would be to take your hard drive out and put it into a desktop computer then turn it on and your have access to your c drive.
    then when your done you can use partition wizard bootable to repair the sectors and format the drive or use format it with the desktop your using by right clicking on the drive and hitting format. After you format it just install windows xp and put in the cd key.
    ps: if you format your drive it should be in ntfs. FAT would work, but wouldnt allow you to put files i believe up to 4gbs or something like that.
  1. Windows XP w/wireless Linksys USB vs NetStumbler trying to wardrive
    By clean customs in forum Wireless Communications
    Last Post: 01-07-2009, 11:18 AM
  2. Need assistance improving boot time - Windows Xp - 12s
    By hidddenh in forum Operating System Optimization
    Last Post: 02-12-2008, 04:15 AM
  3. Another crazy mod: RAM booting XP (no, not EWF)
    By SFiorito in forum WinNT Based
    Last Post: 01-18-2007, 07:39 PM
  4. Can I upgrade XP home to prefoessional?
    By Skipjacks in forum Software & Software Development
    Last Post: 01-30-2005, 08:06 AM
  5. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 05:07 PM
