Results 1 to 6 of 6
Thread: Computer randomly shuts down
    Variable Bitrate Ramanator's Avatar
    Feb 2007
    Motor City
    This is getting frustrating. After having THIS problem the computer is now shutting down unexpectedly. Searches have revealed power supplies and registry errors. I am wondering if the problem is registry errors since the computer is hooked up to a wall supply.
    If you cant DODGE em, RAM em.
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    Shutting down like powering off? Or shutting down like rebooting?
    Tidder
    Try RevFE
    Feb 2007
    Motor City
    powering off.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Is there a common thread to the shutdowns? For example, does it run for say, 10 minutes and then shut down? If so, it could be overheating.
    Try a utility like Speedfan to monitor both temps and voltages and log them. Then you can either identify or eliminate those as the problem.
    Want to:
    Sep 2003
    New Mexico, USA
    Also, just because it's hooked up to a wall supply doesn't mean you should rule that out as the issue. Try another PSU for fun.
    Tidder
    Try RevFE
    Jan 2011
    No BSOD or anything, just cuts off?
    If your sure the PS and hardware is good, at this point I'd really recommend backing up your files, wipe the drive and reinstall XP. Unless you have a ton of programs installed, reinstall is easier than troubleshooting IMO.
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. Replies: 5
    Last Post: 11-08-2005, 10:04 PM
  3. xm mic in, computer shuts down.
    By kembond in forum General Hardware Discussion
    Last Post: 07-30-2005, 09:20 PM
