Results 1 to 7 of 7
Thread: Blue Screen issues in XP (ntfs.sys).
    Sep 2002
    New Jersey
    Hey guys, my CarPC has been in my Acura TL since Sept 2007 and I haven't had a single issue with it until recently it started freezing (audio would have a cd "skipping" effect). Sometimes it would come out of it and resume sound like normal, and a lot of the times I get a blue screen. I'm assuming since I haven't changed anything with drivers/config lately, it's going to be hardware related?
    I have ran a full chkdsk and it came up with no issues.. I'm not really sure how to diagnose what is causing it. Sometimes when the PC freezes, I hear kind of a chirping sound coming from the PC. I can't tell if its from the hard drive, or motherboard though. Of course I pulled the PC and ran it for a couple days in the house and it never froze, the day after I put it back in, its freezing again.
    STOP: 0x0000007A (0xC07B9768, 0xC000000E, 0XF72ED836, 0x14B73860)
    Ntfs.sys - Address F72ED836 base at F7298000, Datestamp 41107eea
    Jetway VIA C7 1.5GHz Mini-ITX Motherboard
    Kingston 1GB PC4200 CL4 240 PIN DIMM Memory
    Maxtor 120GB 7200RPM IDE Hard Drive
    M2-ATX PS
    Thanks for any assistance!
    1991 Camaro Z28
    2004 Acura TL
    Variable Bitrate rijndael's Avatar
    Apr 2007
    on Earth
    hopefully you still have your OS install CD (Im assuming XP), as you will have to recover that file from the recovery console. google ntfs.sys blue screen and you will find out how to fix it.
    Trouble deciding on car speakers? Clicky Clicky
    Speakers: DLS Ultimate Iridium 6.3 Link
    Subwoofer: removed
    Amplifier#1 (Front Stage): DLS Ultimate A4
    Amplifier#2 (Sub) removed
    Carputer: Removed for tablet install
    Dec 2010
    Right click "my computer" and go to manage, then click on event viewer and check system. You should see an error and you can figure out what it is from there(a lot of times with XP it's a driver that you can just dl a new one, with the blue screen a lot of times it's the storage driver)
    Dec 2007
    Sydney Australia
    I'm with you on the hardware thing Slayer.
    You mention that it did not freeze when you brought it into the house but did once it was back in the car.
    What are you using for power in the house is it the same startup controller as you have in the car or a different supply ? Do you have all the same devices plugged in ?
    Maybe there is something wrong with a connection in the car 12V and once XP starts up a few devices the power drain is too much.
    I had a similar issue with a dvd drive during an install as the usb power was not enough to restart the disc spinning if it momentarily stopped. Powering the drive from a different source fixed that problem.
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    May 2006
    Calgary, Alberta
    I had the exact same problem, it turned out to be an issue with RoadRunner and iGuidance both trying to access the GPS receiver on the same port at the same time. Once I ran xPort3 to split the port into 2 virtual COM ports and then assigned each program its own port, bingo bango, things were perfect.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    2005 Honda Civic
    Jun 2011
    Houston Texas
    The majority of the time it is an xp driver. If you have an incorrect driver installed. Happened to me all the time with my wireless internet driver.
    Nov 2010
    Typically when I see this issue in the shop, it's due to a failing hard drive or a corrupt windows install. I would try to run hard drive diagnostics on the drive (let me know if you need help with this), and see what it says.
  1. Blue screen
    By junjun in forum Newbie
    Last Post: 06-14-2010, 02:53 AM
  2. Device Issues / Hibernation Issues / and Screen Question!
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 01-09-2008, 04:46 PM
  3. blue screen of death issues
    By PhatMo in forum General Hardware Discussion
    Last Post: 01-08-2008, 01:24 PM
  4. Blue screen... WIN32K.SYS?
    By zyr55 in forum General Hardware Discussion
    Last Post: 05-05-2007, 04:10 PM
  5. Lilliput "Blue Screen" Issues
    By LekanB in forum LCD/Display
    Last Post: 05-26-2004, 12:14 AM
