Results 1 to 9 of 9
Thread: 2006+ Honda Civic Carputer with dashkit?
    Low Bitrate uptpilot's Avatar
    Jun 2005
    Oklahoma City
    Lightbulb 2006+ Honda Civic Carputer with dashkit?
    I have a 2011 Honda Civic which is basically a 2006+ model (same interior I think).
    I want to install a carputer but I don't see any easy way to do it. Here's what the OEM unit looks like:
    My car doesn't have the OEM head unit and looks like this:
    http://www.automobilesreview.com/img...ivic-gx-07.jpg
    I found that Metra has a kit that is very similar (probably exactly the same?) as the OEM head unit.
    http://www.autotoys.com/x/product.ph...cat=502&page=1
    So while I can fit a 7" touchscreen in there, I don't know how I can keep my OEM radio, which the Carputer would rely on for audio. I also want to keep all the steering wheel controls working on it.
    Does anyone have any idea how I could use my Carputer with a dashkit like this and keep the OEM head unit + air conditioning controls?
    uptpilot
    Jan 2008
    um, you would not be able to keep the factory radio while installing a carpc screen in the same location.
    i would recommend mounting the screen above or below the factory hvac/radio cluster.
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Jun 2005
    Oklahoma City
    Quote Originally Posted by soundman98 View Post
    I know that I can't have both in the same place... the problem is that I want to move the stock radio below the dash (above/in front of the shifter) but I haven't seen any dashkits that do a clean install of the OEM radio in that spot below. I'm not good at fabricating my own headunits.
    Jan 2008
    nope, and you won't find any. there just isn't a demand for that, so companies like metra don't make them.. you'll need to turn to a custom audio shop for that then.
    HID retro--100%
    Moderator - CarPC News Penzance's Avatar
    Jan 2010
    Tennessee
    Especially since the OEM radio is not a standard din size. If you want to keep a head unit, it would probably be a lot easier to buy an aftermarket unit and mount it where you are looking at. I think there are some installs like that over at 8thcivic.com.
    Jun 2005
    Oklahoma City
    Quote Originally Posted by Penzance View Post
    I wouldn't mind loosing the headunit all together provided:
    - I can interface the steering wheel controls with the carputer (next/previous track & volume up/down)
    - I still have some master volume control rotary dial (preferably OEM)
    - The automatic volume control feature can be retained (somehow changes volume based on car speed)
    - I have some kind of radio tuner using existing antennae
    I don't know anything about car audio systems, but I assume that I could replace the head unit with some kind of amplifier that powers the car's OEM speakers? It would need to interface with existing car electronics to provide roughly the same capabilities mentioned above.
    Any ideas? I'll look at 8th civic.
    Feb 2008
    it is easier to buy a OEM head unit directly. most of them are support the steering wheel controls
    Jan 2008
    no it's not. in the OP's case, the factory head unit does not conform to any standards at all. so there is no easy/cheap way of moving it..
    they make steering wheel control interfaces for aftermarket radio's:
    http://www.crutchfield.com/p_127SWIX...ntrol&skipvs=T
    and aftermarket radios conform to the DIN standard, so radio placement is going to be easier.
    HID retro--100%
    Jul 2011
    Civic 2011 & 2012
    Hello,
    Honda civic 2011 is not 2006+ and I think it is hard to install carputer with dashkit.
    Honda Civic is going to have a new shape in 2012 ... Honda Civic is always my favorite
    John Klien
  1. 2006 Honda Civic EX
    By NightHawkFG in forum Worklogs
    Last Post: 06-18-2008, 06:53 PM
  2. 2006 Honda Civic LX
    By Wetzel in forum Worklogs
    Last Post: 04-07-2008, 10:44 PM
  3. Honda Civic 2006
    By dhantiflag in forum Worklogs
    Last Post: 01-10-2007, 06:12 PM
  4. 2006 Honda Civic Stereo
    By majestik12 in forum Car Audio
    Last Post: 09-21-2006, 10:19 PM
  5. Replies: 1
    Last Post: 08-02-2006, 06:03 PM
Tags for this Thread
