Results 21 to 30 of 31
Thread: Air Flow/Fans for trunk computer build - is this how it should be done???
  1. #21
    Constant Bitrate doncarbone's Avatar
    Aug 2010
    Quote Originally Posted by soundman98 View Post
    if you have enough space in the spare tire cubby, that might be a better location.
    you could put some ductwork to feed to/from the cubby to the cabin, and because it is a smaller area, it should be a little easier to keep cool, instead of trying to cool the entire trunk...
    im actually not attempting to cool the entire trunk. it may have not been very clear on my diagram, but the computer is in its own chamber underneath a raised trunk floor. it will be sealed tight with fibreglass on the inside.
  2. #22
    Aug 2010
    Quote Originally Posted by TruckinMP3 View Post
    Do you "need" that much processing?
    Anytime you step up the processing amounts you add complexity to p0wer & cooling solutions.
    Not really lol, but its only a 65W dual-core and according to people who have used this CPU before, it runs cool.
  3. #23
    Elsewhere
    Quote Originally Posted by doncarbone View Post
    Have you actually measured CPU temps?
    I think that would be far more reliable than the statements of "people who have used this CPU before".
    Considering you're going to install in a location that has a high possibility of overheating, this is something I would want to verify for myself.
    How about the Wiki?
  4. #24
    Aug 2010
    no but having built a few overclocked machines before, im fairly confident a small 65W dual-core isnt going to produce a ton of heat...not to mention, i won't be doing any gaming or running multiple processes on my carputer
    but for the sake of playing it safe, how can i go about measuring the temperature of my CPU? is there a resource online that has data on different CPU's avg temperatures?
  5. #25
    Elsewhere
    Get some software like HwInfo32 that can measure them and run the computer through its paces.
    How about the Wiki?
  6. #26
    Jan 2008
    Quote Originally Posted by DarquePervert View Post
    in a confined space like what you intend to install it in. otherwise, a well-ventilated area like a workbench might give better then expected numbers.
  7. #27
    Aug 2010
    Just ran hwinfo64...computer is in my basement, its a hot day and with both my fans running and blowing air at heatsink, the CPU was running at average 16.0 C (or 60.8 F)
  8. #28
    Elsewhere
    I'm sure the ambient temps in your basement are nowhere near the same as the trunk of your car.
    How about the Wiki?
  9. #29
    Aug 2010
    lol well no ****, but what ive established from running this, is that this CPU does indeed run COOL
    my gaming rig in the same part of the house, with an overclocked quad-core was running average 42C
  10. #30
    Newbie jamee's Avatar
    Jun 2011
    Mi
    I think the original diagram you made would work as long as you use 2 intake 120mm and 2 exhaust 120mm, and if you could exhaust the air *right* after the pc. Do you have any idea on the cubic foot that area would be? Obviously you'll need more air flow for a larger volume
  1. Replies: 14
    Last Post: 02-27-2008, 06:43 PM
  2. Sub and Computer in trunk?
    By bombdigity in forum Newbie
    Last Post: 06-19-2007, 03:14 PM
  3. Trunk Computer installs
    By DustinR in forum General Hardware Discussion
    Last Post: 04-19-2004, 05:54 PM
  4. Fans, PDA, SBC Computer system and more
    By Phrozenpenguin in forum Classified Archive
    Last Post: 03-04-2003, 05:34 PM
  5. Securing computer in trunk?
    By Stalemate in forum General Hardware Discussion
    Last Post: 01-23-2000, 01:22 AM
