Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 54
Thread: Zotac ZBOX Nano E350
  1. #41
    May 2004
    Quote Originally Posted by Champak View Post
    Thanks. You were both right and wrong, maybe you could clear this up for me just for the sake of knowledge. I didn't pair my GPS, so that's why I didnt see any ports. However, I restarted after I paired and didn't turn on the GPS and the ports were still listed, but you said something has to be connected.
    I'm guessing that since it was paired once, that comm port is now dedicated to that device for future pairing and is why it's showing still.. Just guessing though.
  2. #42
    Dec 2007
    NY
    So as far as USB stuff goes, because I plan to ditch the bluetooth for a usb gps, once I unplug it the com port will go as well, and then back when I plug it in?
  3. #43
    May 2004
    In theory yes. But on my AD10 I've seen the USB ports act kind of quirky. However, I don't think I've noticed any oddities since I performed the BIOS update.
  4. #44
    May 2004
    Zotac Zbox AD10 power jumper
    stretch, I used your photo to indicate the power jumper on the board. I tested it a couple times to confirm. I've got my CNX-P1900 in hand now. Just waiting on a few more odds and ends and I'll start getting this all wired up.
  5. #45
    Oct 2006
    is it possible for you to check whether this board could output a very low resolution of 480x234?
    i would love to go with this option as well, but i'm worry that newer chipset might have problem with really low resolution.
    Thanks!
  6. #46
    Dec 2005
    Raleigh, NC
    I'm very much interested in replacing my current car PC with one of these little guys. Two questions though: what are the dimensions of the motherboard once it is extracted from the case and have you discovered any way to cut the POST time down from the 7s you experienced the first time?
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
  7. #47
    May 2004
    Quote Originally Posted by blafrisch View Post
    Mine is about 4.5 seconds to Windows loading screen and at about 20 seconds It's in Windows and connecting to wifi.
  8. #48
    Dec 2007
    NY
    The lowest resolution is 640 x 480.
    The board is about 0.25" to 0.5" smaller than the case all around. The case is 5" x 5".
    Note you will want to get a stronger wifi antena.
  9. #49
    Jun 2007
    Boston MA
    Can the microphone input also be used as a line-in, or is it mono?
    My Project: All-in-one Double Din Unit
  10. #50
    Oct 2006
    thanks!
    is it that windows display setting? does AMD have a custom resolution setting like NVIDIA?
  1. Replies: 11
    Last Post: 02-16-2012, 04:49 PM
  2. Zotac's Zbox HD-ND22 barebones mini PC
    By Penzance in forum CarPC News
    Last Post: 09-11-2010, 02:34 AM
  3. Zotac ION A w/M4 ATX
    By tlturner in forum M4-ATX
    Last Post: 11-25-2009, 11:24 AM
  4. Seen this yet? Zotac
    By GTPDan in forum General Hardware Discussion
    Last Post: 11-17-2009, 06:37 PM
  5. MobileVu Universal PC/Ford Econoline E350
    By jeffmccann in forum Show off your project
    Last Post: 05-22-2008, 11:26 PM
