Results 1 to 10 of 10
Thread: HDMI to Optical Question
    Jul 2011
    Not quite sure where this should go, so I'll start here.
    Im trying to get an optical out connection to run from my Motorola xoom tablet to the processor of my car.
    I bought a hdmi to component/vga converter off amazon here: http://www.amazon.com/gp/product/B00...00_i02_details "HDCP HDMI to VGA + SPDIF RGB Component Ypbpr Converter v1.3b"
    Video works, but I cannot get the optical connection working. I am using this hdmi cable which supports up to 1.4. http://www.amazon.com/gp/product/B00...00_i00_details. The optical light doesn't even turn on on the adapter when using the tablet. As a test I plugged in a DVD player and everything worked fine (audio and video).
    Am I making a fundamental mistake here? How can I go from a Motorola xoom starting with either usb or hdmi out to optical/toslink? FWIW, I don't care about having video out at all.
    Apr 2008
    Did you test it on a HDMI TV to make sure it is even putting out audio over HDMI? I know that the Skyrocket (android phone) doesn't all the time only if it "feels" like it (Im sure it has to do with the item its connected to). I know also that there is, in settings, a check mark for "audio out when docked" (something like that) maybe check that? I would start by connecting it to a TV with HDMI just to make sure it is even outputting audio. Hope this helps a little.
    Dave
    Jun 2010
    Vancouver, Washington, United States
    This is from the Amazon page you linked for your converter:
    "Support audio output : R/L analog 2CH Stereo Sound"
    That sounds like the red and white RCA ports are the only supported audio output. Maybe the optical port is an input?
    Jul 2011
    From the Amazon link you provided
    "One HDMI input signal convert to one YPbPr+R/L or VGA+SPDIF sink device"
    Maybe VGA plugged in activates the optical?
    And didn't it come with a manual?
    Jul 2011
    Quote Originally Posted by Ryven View Post
    I don't think so. The RCA ports are for use when in component out mode. Else, optical and VGA should be used together. The test I did with the DVD player confirmed this.
    Quote Originally Posted by davedave1234 View Post
    Dave
    Yeah I checked it out with just the tablet and the hdmi cable into my tv first. Everything worked just fine.
    Aug 2007
    I need you guys opinion and suggestion.
    Can i use <a href="http://www.octavainc.com/HDMI%20distribution%20amp_splitter%202%20port.html ">this one</a> to have digital out for my Huawei MediaPad Tablet?
    Aug 2007
    Yaks, i can not make html <a> href attribute for
    http://www.octavainc.com/HDMI distribution amp_splitter 2 port.html
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    Quote Originally Posted by bandung_steve View Post
    That's because you can't use HTML in forum posts. You use BBC codes.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Aug 2007
    Thamks Kegobeer, i will learn more
    Jul 2011
    Hm, seems like an expensive option.
  1. Replies: 7
    Last Post: 01-06-2008, 10:19 PM
  2. Replies: 8
    Last Post: 10-11-2007, 02:10 PM
  3. Help with Audigy 2 NX optical in --> optical out
    By hithere in forum General Hardware Discussion
    Last Post: 05-22-2007, 03:35 PM
  4. optical drive question
    By johnnm in forum Newbie
    Last Post: 03-29-2006, 07:22 PM
  5. XM Direct optical out to Catalina question
    By Lord_Pall in forum General Hardware Discussion
    Last Post: 01-16-2005, 07:16 PM
