Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Replace Gauge Cluster with LCD Screen?
  1. #11
    Jun 2012
    Portland, OR
    I would also be interested in setting up an LCD gauge cluster in my chevelle. I'd like to research doing it using the standard gauge inputs and also via OBDII (if I decide to go with an LS engine/electronics setup). I'm not as concerned with boot time at this point as that's something that can be looked at down the road. Now I'm more interested in what kind of LCD is available in semi standard gauge panel shapes and what components are necessary to integrate the gauge signals. After an hour skiming these forums, I haven't found much of help.
  2. #12
    May 2012
    Dallas, TX
    Welcome to the forum!
    That's another thought I had, instead of going through OBDII (which in my car, is quite slow, about 8 PIDs per second), interpret the factory gauge signals. That would provide live data feed instead of pulsed through OBDII. The thing is, that's way out of my league of knowledge. I'm a software developer, not a hardware guru. If I find anything, I'll let you know.
    Check out they have sort of what I'm looking to do, but I want actual LCD screens instead of those LCD boards they use.
  1. LCD Monitor Gauge Cluster
    By warrenb213 in forum mp3Car Innovation Grant - Get One!
    Last Post: 04-19-2011, 12:09 PM
  2. Replace oem nav screen with aftermarket?
    By djtodd in forum LCD/Display
    Last Post: 02-23-2011, 08:58 PM
  3. PCMSCAM Gauge Cluster
    By Freestyledork in forum Software & Software Development
    Last Post: 05-20-2009, 12:18 AM
  4. Convert factoy digital gauge cluster?
    By 99bravada in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-12-2004, 01:09 PM
  5. Gauge Cluster Scan for civic
    By SurfinCajun in forum Off Topic
    Last Post: 03-06-2002, 10:38 PM
Tags for this Thread
