Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: fiberglass custom console
    Feb 2000
    hoppers crossing, victoria, australia
    ok dunno where i should post this but here will do
    to make the frame i screwed any main parts together for the lil bits i used a staple gun and hot melt glue
    i think its comingt along good
    any questions im more than happy to answer
    Fiberglass console
    cheers
    pcman
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    Maximum Bitrate Skippman's Avatar
    Mar 2002
    St. Louis, MO
    Looking good so far!
    Stereo:Alpine IVA-D900 Head Unit | Alpine PXA-H510 DSP | Boston Pro Component Speakers Upfront | Boston Rally Rear Speakers | 2 Polk 10" Subs in the Trunk | Phoenix Gold Ti900.7 Amp
    Apr 2002
    Lafayette, LA
    I'm looking to do something very similar. What exactly did you use to get the hard surface at the end? I know that you coated the fabric in resin. What type of fabric is good for this installation? What are some tips for doing this?
    Jan 2003
    Ruston, LA
    fleece
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Sep 2001
    Could you describe how you are planning to attach this to your car?
    Feb 2000
    the fabric is the type used in cheapo jumpers
    its about 3mm thick i just brushed on a light layer all over it then poured lots of resin over it dabbing it into the fleece then once it started top set i mixed up some more resin and dabbed it in from underneath
    some tips for the fabric is stretch it lots and take ya time ans use lots of staples some ppl say to use hotglue to hold it in place but it just dont work for me if its even a bit loose it will curve when you put the resin in it then you have to fill it up with bog (bondo i think its called in usa)
    i checked it a few mins ago and its damn solid now i dont think im gonna have to add any extra fiberglass to it thats a good thing
    to attatch to the car im screwing some angle iron to the base of it will be bolted through the floor with the nuts welded on underneath overkill yes but i dont want it to get stolen the top of the lcd will have have fiberglass brackets made to bolt it to the dash
    cheers
    pcman
    Sep 2001
    How are you going to tighten the bolts when they are underneath the fiberglass structure?
    Feb 2002
    Redding, California, United States
    You do some really nice fiberglass work, a lot of planning went into that, I think it will come out very well.
    Old School MP3CAR.com member!
    Feb 2000
    thanks dscustoms glad you like it this is my first main fiberglass project i take my time ive done fiberglassing b4 but only rust repair that always turned out crap
    supermatty the 2 rear bolts i will be able to get at from behind the front 2 will be set in fiberglass and they wont turn the nuts will be under the car and i will tighten them from underneath for the rear 2 with help from a friend
    2 new photos for yas the resin has almost set i put more on this morning and its cold so ita taking a long time to set
    either refresh the page or check these 2 links
    1
    2
    cheers
    pcman
    Jun 2003
    Nebraska
    how much does that fiberglass stuff cost?
    and will you need to add a clear coat or something to smooth it out when you're done?(sorry if this has already been mentioned)
    looks hot
