Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: PWM to discrete on\off
  1. #11
    Oct 2005
    Norway
    Led
    I would attack this problem from another angle; Simply change out all the bulbs in your runningboards and puddle lights with LEDs, then you can attach your lights directly to your dome lights. If there's many lights and you're still in doubt, then change all your dome lights with LEDs as well then the load should be lower than it was original. I did a complete LED conversion on my 2001 Tahoe, it uses less energy and gives more light output and looks better than stock
  2. #12
    Raw Wave
    Nov 2009
    A good suggestion.
    Though I tried a "led replacement" for my dome years ago (what a joke!), the newer LED is great. MUCH higher & better output. It seem to illuminate much more - maybe its much whiter light - and it isn't wrecking its holder & cover like the old 5W bulb's heat did. And its much brighter than a 10W bulb.
    IMO no doubt - LEDs are now the superior lighting method.
    Using LEDs with or instead of the dome etc bulbs assumes PWM dimming if linear dimming is desired.
    Quote Originally Posted by sredmyer View Post
    Another question, how can I tell whether the dimming is signal is an analog one or is in fact a PWM?
    The easiest might be to parallel a LED (string) with the dome.
    If the LEDs dim linearly, it's PWM - ie, LEDs should dim fairly proportionately to the bulbs.
    If analog, the LEDs will tend to dim slowly from full bright before a sudden dive to off (probably when bulbs are still ~1/2 bright).
    Standard DMM voltage ranges cannot determine PWM signals, though some DMMs have a frequency setting that might be useful (assuming you aren't measuring noise - but PWM frequencies are constant except for rare situations).
    A True-RMS voltmeter should detect PWM. With a load (resistor, LED, bulb) the RMS voltage should drop. The RMS voltage (like the current) should reduce linearly (in proportion) with the PWM duty cycle.
    Ironically (pun), old moving-coil voltmeters meters should also indicate PWM as their moving iron mechanism (get the pun now?) measures the average voltage & current.
    Though DMMs are supposed to measure average values, they actually measure a peak value and scale from that - ie, x1 for (ripple free) DC, and x0.636 for AC. (ie - "sample & hold" circuits: sample, hold, then convert to digital; then re-sample & hold etc.)
    FYI - For a sinusoid, the average voltage = 0.636 times the peak voltage. Same for current. Hence incorrect readings for non-sinusoid waveforms. (Big impact on current readings for SMPS systems!)
    BTW - signal frequency can have an effect. But True-RMS meters should have a wide bandwidth - ie, measure from DC to many Hertz (100kHz? MHz?) so that all sinusoids are measured. (Any wave shape can be represented by a series of sinewaves at different frequencies. That includes square waves, triangular waves, music waves, though I'm unsure about Mexican waves.) I assume True-RWM meters (still?) use DSP techiques (Digital Signal Processing).
  3. #13
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Another question, how can I tell whether the dimming is signal is an analog one or is in fact a PWM? Steve
    The simple way to find out if a signal is PWM or DC is to measure it with the meter on AC range.
    A DC voltage will NOT show on the AC range.
    A low frequency PWM (vehicle light dimming) should give a good reading on AC, especially on a DVM.
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
