Results 1 to 10 of 11
Thread: Rear speakers output same as front
    Mar 2012
    I'm running RR on windows 7 with on board realtek high definition audio. Until I get audiomulch in place I just want to have the rear speakers output the same as the from without using a splitter. I tried searching around on Google and couldn't come up with a good solution. Anyone have any ideas?
    Sent from my HTC One X using Tapatalk 2
    Jan 2008
    there might be a option in the realtek software to 'enable rear fill' but that is the only way i know of to get it to work that way.. but none of my boards had it, so i've only heard of it's existence, so i couldn't tell exactly where it is..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    MySQL Error
    Oct 2004
    not possible... (with just reltek controls)
    technically copying the front audio to rear is WRONG, but thats what we do in CAr audio
    SO OPTION #1
    SOME software has to tell windows(which is written for THEATER audio) to send the front to the rear
    (virtual audio cable + audio mulch) would do it, but complicated
    also.. u could do it for a specific program, say foobar2000, there is a nice output channel mapper plugin
    same for winamp called vista sound, but buggy and i think its messing with sample rates... so im not sure of SQ
    i have no simple solution...
    funny enought, someone could make one
    just need a virtual soundcard, that does the pcm buffer copy and sends to say, front and rear
    one thing you do need to do is set your output in realtek manager to 5.1 then DISABLE; center
    (side pair, becomes rear pair)
    REMEMBER WINDOWS/PC AUDIO MADE FOR HOME THEATERS!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    btw the channel mixer in foobar2000 VERY COOL... can control lots!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mar 2012
    Thanks, I had a feeling this seemingly simple request wasn't that simple. I realize rear fill in a home theater setting isn't correct, but it is a popular option as most people are after being loud more than proper stereo imaging.
    I have thought about using foobar with a plug in but I believe it has one major limitation, and you can correct me if I'm wrong, but it would only work for audio originating from foobar, where using audiomulch would work for all audio, like blue tooth phone, navigation, etc.
    My rear output is used for my mid bass speakers and until I get my sub in I'm just going to use my crossovers on my amp. Once I get my sub in ill be forced to do full active. Maybe I should just stop putting off the inevitable and install audiomulch now.
    MySQL Error
    Oct 2004
    course, solutions is audiomulch...
    or somone smart write a virtual sound card
    audio mulch with virtual audio cable
    i played with it got it working wasnt too bad, nice thing is you can put VST componenets in play
    like 31 band eqs
    basically you set windows default playback device to the VAC...
    something tells me this isnt perfect too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Apr 2012
    Radelaide South Aus
    Hi
    I havnt done this yet so its all theory
    download the full k-lite package http://codecguide.com/download_kl.htm
    install it and then in the startmenu you will see a configuration folder in there is the "ffdshow audio decoder" app
    run this and in the mixer tab you can set up a custom matrix, which should allow you to mix what channels go where. You can also select to expand stereo to surround ,what apps use this decoder in the directshow control tab..there is even winamp section
    Cheers
    Wozza
    Jan 2008
    Quote Originally Posted by Wozza View Post
    Hi
    Cheers
    Wozza
    is that supposed to add to the realtek menu system or is it a separate program that interfaces with windows?
    Quote Originally Posted by mitchjs View Post
    no, it's not the 'best' route, as it still uses the WDM drivers-- the best route is supposed to be while using ASIO drivers-- they are supposed to have better clarity. i tried both, and i couldn't tell a difference..
    HID retro--100%
    Apr 2012
    Radelaide South Aus
    Quote Originally Posted by soundman98 View Post
    separate program which sits between the media app and windows default output..or it may even bypass the windows sound system..as I said haven't really played with it much yet
    MySQL Error
    Oct 2004
    best would be a custom driver, but with everything really requring digitial signatures
    only mfg can afford to do this..
    and they not going to for the small carpc niche market
    many more people use pc for gaming and HT than funky car audio...
    a pc controled external audio dsp system would work
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 0
    Last Post: 03-11-2011, 05:10 AM
  2. Balancing sound output of front and rear speakers
    By bemenaker in forum Car Audio
    Last Post: 02-18-2009, 02:38 PM
  3. Rear speakers not going :(
    By samael in forum Car Audio
    Last Post: 08-13-2005, 02:33 AM
  4. rear speakers?
    By kuwupt in forum Car Audio
    Last Post: 11-08-2004, 07:57 PM
