Results 1 to 4 of 4
Thread: Cheapest way of installing "Android" in my car?
    Nov 2011
    I've looked around for hours now and I think my head is going to explode.
    Basically it's a simple concept, I have a double DIN space and I want to integrate some sort of Android solution with touchscreen, I'm terrible with DIY so I can fabricate any moulds or make any modifications so it needs to be simple! So far I'm considering
    Pioneer AppRadio -With all the neccessary hacks it seems I can use my Galaxy S3. This is perfect as I won't need a seperate amp, but relatively expensive (around £340 with all the cables I need it seems)
    Mimics X2 - This will cost around £310 and I'll still have to use a seperate amp (which I'll just hide in the glove compartment)
    Now there is the other option of just using a cheap 7" tablet and my current amp, this would be perfect except apart from mounting it somewhere. Does anyone make a kit to mount a tablet into the double din space?
    Are there any other options? Thanks for any help anyone can provide.
    Low Bitrate SierraStroker's Avatar
    Nov 2012
    Quote Originally Posted by elliotsam View Post
    Tablet + velcro? Haha.. it would work, just depends on how pro or ghetto you want it to look. Or you could get a single din HU, one of the spacer kits that blanks out the upper, screw a hinge into the blank upper and attach the other side of the hinge to the tablet. The tablet could cover the HU when you didn't need it and a short headphone to headphone cable could link the two together. Get it usb power somewhere and you're done. You might have problems with it bumping the buttons on the HU this way though, so get some rubber feet to attach to the HU so it clears. If you attached it with magnets or velcro somehow you could also take the tablet with you when you got out of the car.
    Again, its ghetto, but if you did it right it wouldn't be THAT ghetto. I sorta doubt you'll find a double din mounting kit for a tablet as they vary in size a lot and I dont see a lot of market for something like that.
    Not sure what you expect in terms of professionalism when you're not willing to fabricate anything though. I'd say just take a stab at making something custom, just go find yourself a 2nd dash bezel at a junkyard so if your project goes horribly wrong you don't end up with a ****ed up car.
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Tablet installs or mounts can be relatively inexpensive anyways. For the most simplest cheap solution just mod a double din kit for your car to hold your tablet. Thats what I did. The only thing you have to figure out is if you want to keep your headunit or not. The rest depends on what you decide on.
    Sent from my DROID BIONIC using Tapatalk 2
    "Live Free!!!...It's all about Open Source"
    Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
    Nov 2012
    Quote Originally Posted by hexxamillion View Post
    Ya I've been thinking about installing the kindle fire that I never use into the visor of my truck. Would be nice for displaying cameras, video, nav, whatever. Not sure if there's a kindle compatible gps unit anywhere, but I suppose I could use DLNA from the main carpc to put just about anything on the kindle's screen.
  1. Replies: 14
    Last Post: 07-28-2012, 01:20 PM
  2. Replies: 7
    Last Post: 07-14-2011, 05:56 PM
  3. Hyundai Android "Hybrid" Technology - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 01-08-2011, 12:24 PM
  4. Replies: 2
    Last Post: 08-09-2004, 02:49 PM
  5. Cheapest 5.6" touchscreen?=
    By DrSergioDJ in forum LCD/Display
    Last Post: 01-19-2004, 01:34 PM
