Results 1 to 5 of 5
Thread: Hibernate - Windows XP v Windows ME
    Constant Bitrate captain_jim1's Avatar
    Nov 2002
    New Jersey
    Hey all -- I had written a small program that would detect whether or not a laptop was running on a battery on AC ... if it was on the battery it would display a message and go into hibernation mode...
    It worked great on WinME .. but when I upgraded to XP it no longer functions. It will detect it's on the battery, but never goes into Hibernation. I have checked and Hibernation is enabled in the Display settings.
    The program was written in visual basic... Thanks!
    -Brad
    83 mp320i 285k
    jol
    jol is offline
    FLAC jol's Avatar
    Jan 2002
    Mellansel, Sweden
    you're welcome.
    Maximum Bitrate osirisdon's Avatar
    Feb 2003
    South Florida
    Originally posted by jol
    you're welcome.
    bwahahhahaha I laughed so hard at this. HILATIOUS!!
    Although the author of the thread, I guess needs help from the programering gurus of these vast lands of information regarding MP3's a quick question??? shouldnt this go into the software section? sounds like software dont it???
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Paste the following code into a module.
    Call anywhere in your program by ...
    ShutDown(shutdownmode)
    where shutdownmode = one of the modes below
    Code:
    'These are your modes....
    Public Const ShutDownComplete = 0
    Public Const ShutDownHibernate = 1
    Public Const ShutDownStandby = 2
    Private Const EWX_LOGOFF = 0
    Private Const EWX_SHUTDOWN = 1
    Private Const EWX_REBOOT = 2
    Private Const EWX_FORCE = 4
    Private Const EWX_POWEROFF = 8
    Private Const TOKEN_ADJUST_PRIVILEGES = &H20
    Private Const TOKEN_QUERY = &H8
    Private Const SE_PRIVILEGE_ENABLED = &H2
    Private Const ANYSIZE_ARRAY = 1
    Private Const VER_PLATFORM_WIN32_NT = 2
    Type OSVERSIONINFO
        dwOSVersionInfoSize As Long
        dwMajorVersion As Long
        dwMinorVersion As Long
        dwBuildNumber As Long
        dwPlatformId As Long
        szCSDVersion As String * 128
    End Type
    Type LUID
        LowPart As Long
        HighPart As Long
    End Type
    Type LUID_AND_ATTRIBUTES
        pLuid As LUID
        Attributes As Long
    End Type
    Type TOKEN_PRIVILEGES
        PrivilegeCount As Long
        Privileges(ANYSIZE_ARRAY) As LUID_AND_ATTRIBUTES
    End Type
    Declare Function SetSuspendState Lib "powrprof.dll" (ByVal Hibernate As Long, ByVal ForceCritical As Long, ByVal DisableWakeEvent As Long) As Long
    Private Declare Function SetSystemPowerState Lib "kernel32" (ByVal fSuspend As Long, ByVal fForce As Long) As Long
    Private Declare Function GetCurrentProcess Lib "kernel32" () As Long
    Private Declare Function OpenProcessToken Lib "advapi32" (ByVal ProcessHandle As Long, ByVal DesiredAccess As Long, TokenHandle As Long) As Long
    Private Declare Function LookupPrivilegeValue Lib "advapi32" Alias "LookupPrivilegeValueA" (ByVal lpSystemName As String, ByVal lpName As String, lpLuid As LUID) As Long
    Private Declare Function AdjustTokenPrivileges Lib "advapi32" (ByVal TokenHandle As Long, ByVal DisableAllPrivileges As Long, NewState As TOKEN_PRIVILEGES, ByVal BufferLength As Long, PreviousState As TOKEN_PRIVILEGES, ReturnLength As Long) As Long
    Private Declare Function ExitWindowsEx Lib "User32" (ByVal uFlags As Long, ByVal dwReserved As Long) As Long
    Private Declare Function GetVersionEx Lib "kernel32" Alias "GetVersionExA" (ByRef lpVersionInformation As OSVERSIONINFO) As Long
    'Detect if the program is running under Windows NT
    Public Function IsWinNT() As Boolean
        Dim myOS As OSVERSIONINFO
        myOS.dwOSVersionInfoSize = Len(myOS)
        GetVersionEx myOS
        IsWinNT = (myOS.dwPlatformId = VER_PLATFORM_WIN32_NT)
    End Function
    'set the shut down privilege for the current application
    Private Sub EnableShutDown()
        Dim hProc As Long
        Dim hToken As Long
        Dim mLUID As LUID
        Dim mPriv As TOKEN_PRIVILEGES
        Dim mNewPriv As TOKEN_PRIVILEGES
        hProc = GetCurrentProcess()
        OpenProcessToken hProc, TOKEN_ADJUST_PRIVILEGES + TOKEN_QUERY, hToken
        LookupPrivilegeValue "", "SeShutdownPrivilege", mLUID
        mPriv.PrivilegeCount = 1
        mPriv.Privileges(0).Attributes = SE_PRIVILEGE_ENABLED
        mPriv.Privileges(0).pLuid = mLUID
        ' enable shutdown privilege for the current application
        AdjustTokenPrivileges hToken, False, mPriv, 4 + (12 * mPriv.PrivilegeCount), mNewPriv, 4 + (12 * mNewPriv.PrivilegeCount)
    End Sub
    ' Shut Down NT
    Public Sub ShutDownNT(force As Boolean)
        Dim ret As Long
        Dim flags As Long
        flags = EWX_POWEROFF
        If force Then flags = flags + EWX_FORCE
        If IsWinNT Then EnableShutDown
        ExitWindowsEx flags, 0
    End Sub
    'Restart NT
    Public Sub RebootNT(force As Boolean)
        Dim ret As Long
        Dim flags As Long
        flags = EWX_REBOOT
    End Sub
    'Log off the current user
    Public Sub LogOffNT(force As Boolean)
        Dim ret As Long
        Dim flags As Long
        flags = EWX_LOGOFF
    End Sub
    Public Sub ShutDown9X(force As Boolean)
    On Error GoTo ShutDown9X_Err
        Dim flags As Long
    Exit Sub
    ShutDown9X_Err:
    msgbox "Error occured in Shutdown Module"
    End Sub
    Public Sub ShutDown(byval SDMode as long)
        'Kill winamp
            If WinAMP_FindWindow Then
                WinAMP_SendCommandMessage WA_STOP
                WinAMP_ClearPlaylist
                WinAMP_SendCommandMessage WA_CLOSE
            End If
        Select Case SDMode
            Case ShutDownComplete
                If IsWinNT Then
                    ShutDownNT (True)
                Else
                    ShutDown9X (True)
                End If
            Case ShutDownHibernate
                'Go into hibernate, force it, but don't disable wake events
                'this may need work, I dont know what these wake events are...
                SetSuspendState 1, 1, 0
            Case ShutDownStandby
                'enable the shutdown privilege
                EnableShutDown
                'on Windows2000: hibernate
                'on Windows9x/ME: suspend
                SetSystemPowerState True, True
                'SetSystemPowerState False, False
        End Select
    End Sub
    Get MediaEngine !!!
    Media Engine Download
    Nov 2002
    New Jersey
    Thanks CarComp .. I'll try that out later tonight..
    -Brad
    -Brad
    83 mp320i
    99 mp323i
    _________
    7" Lilliput w/Touch, 150 W Opus, 2.4ghz P4 533fsb, 512 DDR 333mhz, GPS, WiFi Inet, 40g Maxtor 7200rpm, Laptop DVD/CD-RW w/USB2.0 Bridge, WinXP Pro.
