Results 1 to 8 of 8
Thread: boot/power issue
    May 2003
    Charleston, SC
    boot/power issue
    I just put my PC in the hatch and when I went to power up the PC it starts to boot fine, then right before it gets into WinXP Pro the Opus PS starts squeeling and the boot freezes. I rebooted several times and sometimes it will get all the way into windows before it locks up (before I can do anything of course) & it always locks as soon as I start hearing that squeel.
    Temp. Solution: I took my WinTV card out and everything works fine. Is this card drawing too much power? I tried disconnecting everything but the bare essentials and dropping the RAM from 256MB down to 128MB & even 96MB & this didn't fix anything. If I plug the AC/DC power supply back in, WinXP Pro boots fine with the WinTV card and everything else running. Any ideas?
    P.S. - I'm getting my GPS today (USB) and wireless NIC (PCI)tomorrow so I'll see if those boot up without any problems. If so I guess I'll be looking for a different way to receive FM radio.
    Car: 1990 White Toyota Celica GT Hatchback, Custom CAI w/ K&N filter, AutoVation Celica Racing Pedals
    PC: Athlon TB 1000, Opus DC-DC Power Supply, 40GB, 8x DVD, 256MB RAM, FM/TV Tuner, 5.1 Audio, 7" Xenarc Touchscreen, GPS w/ CoPilot 2003, 802.11g wireless NIC
    System: Hifonics ZX8000 5ch amp, Sony XS-L101P5 10" Sub, Q-Logic .6 cu ft sealed enclosure
    Coming Soon: Clean install in custom hatch enclosure, USB 2.0 or Firewire hub in front console, Slot DVD in front console, VHF/UHF antenna
    Jun 2003
    Atlanta/Augusta, GA
    Any of the indicator leds on the Opus signalling something is wrong? Give Kris at Opus a call.
    For me, the cause was the Xenarc touchscreen. Possibly a bad driver or bad extension cable, but when the serial cable is connected, windows will not always load.
    May 2003
    Charleston, SC
    I don't think it's a driver issue because it comes right up when I hook the ac/dc ps back up & the ps squeeling has me thinking it's overloaded. I'm going to give Kris a call this afternoon when I have the system in front of me to hopefully resolve these issues. He said the +5v output Rail sounds like it's overloaded.
    Phil
    Jun 2003
    try and put the the tvcard in a different pci slot and maby it is macking your cpu overheat
    May 2003
    Charleston, SC
    Thanks...I settled the solution to this problem in another thread here. It turned out my CPU was drawing too much power. After I swapped that out with a slightly smaller CPU everything started working (AMD TB 1.1GHz to AMD TB 1.0GHz). I'm sure I still have a heat issue though, which I should be able to fix once I get everything set up right. As of now it's all like a witchnest in the bottom of my hatch, ewww! I say that because in the mornings & night it boots up great...during the day I've had some problems. Buuuut, that was with the old CPU, maybe this new one will settle those quirks too. Regardless, I have to clean up the install & add some more cooling just incase.
    Phil
    May 2003
    Charleston, SC
    FM reception is comparable to that of any HU once you get the antenna set up right. Both the TV & FM inputs take coax and most car antennas are motorola plugs. The WinTV FM comes with a weird looking wirey FM antenna, but I couldn't get it working good in the car & it was too big to make it look nice and get good reception at the same time. Since I was in need of an antenna anyways, I headed to radio shack and got a black rubber antenna (12"-18") & had to use 3 or 4 adapters to convert from the motorola plug to coax. I could have just soldered on a coax connector, but I was lazy. I'm sure there's an adapter out there somewhere that will convert one to the other, but for the meantime I'll use what I have. I have noticed that the card refuses to work after sitting in the hot sun for a while. I'm not sure if this is a personal issue or an issue with the card, but everything boots up & I get an error "the device is busy or not installed" Again, this is only when everything is pretty hot...once the cab cools down I can restart the PC & the card comes up fine.
    Phil
    Yea I am worried about heat issues with my car-puter as well. I live in South Florida and it gets downright hot during the day. I usually try to park in the shade, but it still gets nasty hot in the car. We'll see how it all works out. I will probably end up wiring the Tuner card antenna into the cars main antenna. Hope it doesn't sound too bad
