Thank you for your input!
You're right, Front End would be a better description for it.
Centrafuse works in images, all the UI is based on static images which can only resize in all directions. So, no matter how big your screen might be, the UI will just scale up in size, which is not very efficient, and looks very bad! Our system is build from the ground in WPF, which enables use of scale much better, as everything is rendered runtime. Take CFs
music screen, only 3.. THREE! songs are visible in the list, no matter how big your screen is, that is simply horrific design! All buttons scale too, buttons don't need to get bigger just because your screen is, therefor, you get room for more content..
I REALLY like your idea of using mythology, we have done a lot of research in finding a name through that, because it has a meaning too, like Icarus!
