Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: getting around factory amp issue
  1. #11
    Nov 2012
    When you add up the shipping and handling buying parts from Digi-Key or Mouser, and the time, it is better (IMO) to buy something that works and adapt it, rather then re-invent the wheel.
    All you have to do short out the input lines and that will mute the sound.
    If you add a resistor, you can attenuate so it doesn't go dead silent.
    On a 10k input I would try a 250 ohm load and see how much that drops the sound.
    The device I gave you a link to will do two lines.
    Add another one to do the four.
    It even has a 12 volt trigger and I bet it doesn't
    "pop" when switching either.
    Here is a device to look at:
    http://www.analog.com/en/switchesmul...s/product.html
    What exactly are you trying to do?
    Do you want to "bleed" the GPS voice commands over the normal audio?
    I would just switch the inputs (FET) and give the GPS priority.
  2. #12
    Jan 2008
    Quote Originally Posted by heavymetals View Post
    that's really going to be the easiest way to accomplish what you want to do. $100 for a complete setup is really quite good.. of course it ruins the diy stuff, but i really don't think you could come in that low diying a solution..
    those units are a little tricky to setup to switch at the right times-- i did a niles amp in a conference room once with an identical feature(they wanted the background music to play through unless there was a conference call/video meeting)--but once they are setup, they don't need to be touched again..
  3. #13
    Dec 2007
    NY
    thank
  4. #14
    Nov 2012
    Quote Originally Posted by Champak View Post
    thank
    What did you end up doing?
  5. #15
    Dec 2007
    NY
    I haven't done it yet because there are a few other things I have to do to the car, but I'm going to follow your suggestions and get one of those devices instead of building one.
  1. Factory NAV
    By manesh in forum General Hardware Discussion
    Last Post: 09-02-2010, 06:09 PM
  2. Car PC -> EQ -> Factory Amp
    By dperkalis in forum Car Audio
    Last Post: 02-13-2009, 02:26 PM
  3. 1/8 to Factory Amp
    By AltimateX in forum Car Audio
    Last Post: 03-21-2007, 02:08 AM
  4. factory sat nav lcd
    By ducki in forum LCD/Display
    Last Post: 03-14-2007, 07:11 AM
  5. Factory look
    By BRINET in forum LCD/Display
    Last Post: 03-26-2002, 11:02 AM
