Results 1 to 3 of 3
Thread: New relay switching needs
    Dec 2007
    NY
    I think this is the last thing i have to do with the computer that is anywhere near complicated. Here is my setup.
    1/ I have the joycon exr and resister with my 3pt steering wheel control that i want to operate both computer and car.
    2/ I have a setup that switches my nav screen between my car and computer.
    3/ I have a 8pt relay and also have a complicated car switch that looks like a 8pt relay, but Ive only been able to figure out the connections to use it as a simple switch.
    How do I put this together to only use the one switch, or is there a bigger more "complicated" relay that I need to get. The way I've figured seems way more complicated than it needs to be. Thanks.
    Dec 2007
    NY
    I think I figured out what I need, I'll post my thinking on how it should be wired later. Let me know if I'm on the right track.
    http://www.alliedelec.com/search/pro...x?SKU=70178841
    my only problem is the type of connections. I would prefer connections like this:
    http://www.alliedelec.com/search/pro...8809#tab=specs
    Dec 2007
    NY
    OK this is what I came up with. Please let me know if it is correct, and where specifically I can get the relay I need. Also, will this relay change the resistance at all? I don't want to mess with the signal going to the head unit.
    My current button specs are:
    990-1030 ohms
    323-337 ohms
    108-112 ohms
    0 ohms
  1. Replies: 13
    Last Post: 03-29-2012, 07:48 PM
  2. OBD-II Switching
    By rabster in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-04-2011, 10:45 PM
  3. e46, Rear-View, Relay... suggestions to relay...
    By house98 in forum General Hardware Discussion
    Last Post: 11-25-2009, 06:06 PM
  4. Wooo, no more relay for the relay
    By MP3DUB in forum General Hardware Discussion
    Last Post: 03-15-2002, 10:21 PM
  5. Switching USB connection On/Off with relay
    By Destin in forum General Hardware Discussion
    Last Post: 09-09-2001, 05:31 AM
