Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Question about ground loop.
  1. #21
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    If you reverse your leads does it show "-" in front of the 0.00? Like -0.00 SNO
  2. #22
    Raw Wave
    Nov 2009
    LOL - I was thinking the same "Never a stupid question..." but paraphrase it as "Never a stupid question, only stupid actions sometimes".
    There are a few basic or golden rules with multimeters. The first I teach is NEVER do a resistance measurement on a powered circuit. (The 2nd is never try to test battery or source current capability by connecting an ammeter across the terminals.) Usually DMMs blow. If lucky, only the internal fuse blows, or other DMM scales may still read ok.
    Ironically the DMM read true - any PSU or battery should ideally be zero Ohms (impedance).
  3. #23
    May 2010
    Herákleion, Iraklion, Greece, Greece
    ok cool. i can leave with that :P my DMM was anyway broken before that
  4. #24
    May 2010
    lol old spark you where correct. i bought a new DMM , And it clearly states, do not measure Ohms, across working power supply's :P . anyway. something last
    if i change my carpc (wich is a desktop one), with a laptop. keep everything in tact, except, that all signals will be from a laptop. and i have the laptop work in battery mode, (no charger connected, ) the loop will be broken, and i wont have any noise?? correct???
    the reason ask, is cause, since history has proven that this damned loop is good for me, i could use a laptop, with and "inteligent" charging system, that shuts off charging of the laptop, when the laptop is on, and after it turns off, it will begin to charge the laptop for a time (time will be depended on the time that the laptop worked) and then shut off. ( i have 2 batteries, so deep discharge isn't a threat )
  5. #25
    Raw Wave
    Nov 2009
    There is no loop with something that is isolated. That's called a portable laptop on the passenger seat.
    Batteries last longer the less they are discharged
    You have loops everywhere, and dc voltage drops (the other reason for "ground loop" noise).
    yTF are you using an inverter?
    Reread what has been posted already.
    (Yeah, I think it's time I bug out....)
  6. #26
    May 2010
    Quote Originally Posted by OldSpark View Post
    yep
  1. Replies: 5
    Last Post: 05-24-2011, 09:29 PM
  2. ground loop question
    By yonu in forum Car Audio
    Last Post: 10-01-2009, 12:11 PM
  3. Ground Loop Isolator Question
    By rich3327 in forum General MP3Car Discussion
    Last Post: 02-16-2008, 11:49 PM
  4. just a quick question on a ground loop problem
    By insensate in forum Car Audio
    Last Post: 08-15-2007, 07:35 PM
