Results 1 to 8 of 8
Thread: Sticky question
    Dec 2007
    NY
    Sticky question
    I'm fabricating something to hold a touchpad. I want to be able to remove the touchpad if there's a problem. What was suggested to me...by people who don't really know this stuff...is to use silicone to glue the edges of the touchpad circuit board to the thing I'm using as the holder which will be abs plastic, this way with a little bit of force and pressure i can pry them apart if needed without breaking it. The contact surface will be 2mm all the way around. My only question is will silicone hold up the movement of my finger over the touchpad and the temps in the car -10 to 110?
    Or any particular glue recommended?
    Thanks.
    Oct 2010
    Greece
    if 10 - 110 are celcius you will have problem with hot glue. in my car it melt down and sticked to the car where now i cant remove. i would say 2 component epoxy would do the job well.
    Jul 2010
    His location lists NY, so I am assuming that the temps he listed are in Fahrenheit... I'll leave someone else to answer the actual question though
    Current Worklog: TBA - '05 Rav4 (Mobo Dead).
    www.rav4world.com - Forums for Rav4 owners
    www.flavorfeasts.com - Cooking website/forums
    -Basic forums live atm, come contribute!
    Oct 2010
    Greece
    Then a hot silicon glue will be just fine. . Keep in mind that when you applying hot glue you have to heat the bonding element. I do this by leaving the pistol o nthe (abs in ur case ) just to make it hot enough.
    I have used in a lot of things in my car pc and monitors hot glue and i am very satisfied.
    Dec 2007
    NY
    So one person says hot glue is good, the other says its bad with these temps. Who's right? Epoxy I believe is too strong. Remember, I want to be able to pop/pry the circuit board from the plastic holder if necessary. Since all of you bypassed the silicone, will assume silicone is a bad idea.
    May 2012
    Grandville, MI
    Hot glue is a bad idea inside a car. As already mentioned if your car reaches high enough temps the hot glue will come "unglued" because it will melt...
    Epoxy if you want to make sure it won't go anywhere..
    Silicone really is a great suggestion. I am looking at an application now where you use high temp Silicone to seal a compartment on the engine that gets near 300F. Just make sure you use a non conductive silicone and one that is rated for high enough temperatures for your car. (Standard non conductive silicone should be good. ) You can check if it is non conductive by using a VOM and checking for conductivity. I made the mistake of sealing some temperature sensors with conductive silicone once not knowing there was a difference... Needless to say the probe didn't work.
    You can generally also use 3M tape but you have to get one that will work in your car. The tape MAY degrade over time but there are body parts of some cars that are taped on originally from the factory... Make sure you get the adhesive strength and temperature range you want. Or just any 3M branded double sided tape will likely work.
    Maximum Bitrate jmullan99's Avatar
    Feb 2009
    Niagara Falls, Ontario
    I use hot glue to mount my monitor in my dash. Hasn't failed me yet summer heat (+40c) through winter cold (-20c).
    03 Cadillac CTS
    ZOTAC G43ITX-A-E 2.5ghz Core i3 2GB 160GB SSD
    Win7 Ultimate - OpenMobile - Directed HD - Wifi
    OMMaps + MS GPS Puck - WiFi via LTE Android phone
    2 Zones - Matrix Orbital LCD - Arduino - Build Pics
    Dec 2007
    NY
    I'm going to try double sided 3m tape, 20lbs first. If that doesn't hold up I think I'll look at non conductive silicone, just a matter of where to get it. Thanks.
  1. Sticky This Please!!!!!!
    By lostreception in forum General MP3Car Discussion
    Last Post: 11-02-2007, 12:01 PM
  2. Read The Sticky, I Still Don't Get It....
    By Maheriano in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 05-18-2006, 01:06 AM
  3. Question about 3M sticky pad with LCD mounts
    By sxt173 in forum LCD/Display
    Last Post: 03-11-2005, 10:13 AM
  4. Need a PSU Sticky
    By SWYZ721 in forum Power Supplies
    Last Post: 10-27-2003, 11:45 PM
