Results 1 to 4 of 4
Thread: car PC "TV antenna problem"
    Mar 2011
    Hello to all forum writers ... I have a question to ask, specifically, I have a problem with a TV antenna to the interior. By testing the antenna with a field meter I found that the PC receives the channel normally off, as soon as I turn on the PC does not receive anything. In your opinion where is the problem? The M4 ATX power supply? or a PC? I tried to shield the houses but nothing has changed. We accept suggestions and advice.
    Someone who uses the TV on car-pc, that solution adopted?
    thanks
    greetings
    Carlo
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    I would have to say M4 is your main cause. You should read mickz post about diagnose and remedy for the M4, it is quite detailed and informative. I use a slingbox and stream my digital cable package from home, just make sure you have unlimited data plan. SNO
    Mar 2011
    Quote Originally Posted by SNOtwistR View Post
    I am in Italy. cable tv does not exist, MAX 2GB data plan to consumption (mobile network).
    Where can I find the post mickz?
    thanks for reply.
    CARLO
    Nov 2009
    Keswick,On Canada
    Took me a while to find it http://www.mp3car.com/power-supplies...ml#post1494006 It's a long but good read. Good luck SNO
  1. Replies: 5
    Last Post: 06-20-2006, 01:20 PM
  2. "Signal too low, check antenna" and XM freeze
    By yunusyu in forum Centrafuse
    Last Post: 04-09-2006, 07:33 PM
  3. USB adaptors & DIY antenna = "Poor Man's WiFi"
    By Terran in forum Wireless Communications
    Last Post: 11-08-2004, 10:52 PM
  4. Replies: 1
    Last Post: 07-07-2004, 09:19 PM
  5. 5" LCD Screen TV Antenna Problem
    By owenjh in forum General Hardware Discussion
    Last Post: 12-16-2003, 04:15 PM
