Results 11 to 20 of 23
Thread: Relay Voltage question
  1. #11
    Sep 2012
    Germany - Munich
    self induction happens when you cut the steering power from relay.
    the magnetic field falls down and induct a voltage back to steering part.
    can destroy yICs, if you don't terminate this selt induction.
    thats why the question where do you get this low voltage.
  2. #12
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    One thing i was thinking of was a mute wire on a parrot bluetooth kit...i believe its 3v when its telling the "radio' to mute and a ground otherwise.
  3. #13
    Sep 2012
    Germany - Munich
    thinking, believing or known?
    does it mean you want mute the radio with this signal?
    do you know which signal needs the radio for mute mode?
  4. #14
    Nov 2011
    I know the parrot outputs a +3v when muting a sterio..i want to use this as a input for a mjs usb in/out or a joycon...either way i want the carpc to pause the current media when i recieve a phone call.however its done i need a alt-D (keystroke)to be issued upon 3v from the parrot...just need to be able to operate a relay from that voltage. Any thoughts?
  5. #15
    Sep 2012
    Germany - Munich
    i think you don't need a relay. this should work with few ampere. so you can use a transistor.
    may be you can connect the signal directly to com-port. but i don't know it.
  6. #16
    Nov 2011
    I was thinking transistor a while back.ill keep looking into it.
  7. #17
    Raw Wave
    Nov 2009
    An whilst pennies drop, the harryberlin's relay problem is solved with the usual spike protection diode (1N4007 or 1N4004).
  8. #18
    Sep 2012
    Germany - Munich
    yes you're right, you can fix the problem with a diode.
    but i think the better way is to use transistors.
    or may be a small reed relay. but not such a big thing.
  9. #19
    Raw Wave
    Nov 2009
    Transistors are not a better way to prevent relay spikes - ie, quenching the spike.
    I don't see what relevance a dc-dc or dc-ac converter has - we are not 'converting' the low voltage output.
    If talking about a transistor for a buffer for the relay coil etc you'd probably use an NPN transistor as on Open Collector output which could ground a 12V relay, or the load direct (if a few Amps), or control a MOSFET or other transistors.
  10. #20
    Raw Wave
    Nov 2009
    I still don't see what relevance it has here - we are not 'converting' voltages nor providing a power supply/voltage. And the OP should have the call if bantering is welcome.
    camo.b's 1.8V or higher output voltage turns on a transistor. That transistor can ground a relay coil, or another transistor. The output else its transistor could also control a MOSFET that can switch loads up to 50A and higher ($2, 100A).
    Not that the OP Champak has yet specified a minimum voltage, but I suspect it'll be above 1.8V - maybe 3.6V etc.
    If switching a relay coil, a reverse biased diode (1N4004 or 1N4007) can be placed across the transistor's Collector & GND, or as is often done, across the relay's 86 & 85 where 85 is the more -v, ie, GND. The Cathode/line end of the 1N4004 or 4007 diode goes towards the more +ve ie, Collector or relay 86. IOW the NON-line end to the transistor's Emitter or relay 85 which should both be GND in this case.
    A 1N4004/4007 diode is the most common solution for relay coil 'self induction', ie the huge -ve voltage spike released by a coil when switched off. (Place your fingers across a non-spike protected relay coil when de-energisied if you don't believe me.)
    The diode spike-suppression solution is ironically the cheapest as well as the best implementation (for common relay applications and electronics).
  1. Quick Voltage Question
    By Ryven in forum CNX-P2140
    Last Post: 07-08-2011, 04:10 PM
  2. LCD Voltage Question
    By piersuk in forum LCD/Display
    Last Post: 08-31-2010, 12:47 AM
  3. Replies: 25
    Last Post: 02-16-2010, 02:32 AM
  4. quick question about dc voltage
    By cdm in forum Power Supplies
    Last Post: 03-05-2004, 04:19 AM
  5. tm701 voltage question
    By h_2_o in forum LCD/Display
    Last Post: 06-19-2003, 02:54 AM
