Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Relay Voltage question
    Dec 2007
    NY
    Does anyone happen to know the minimum triggering voltage to activate this relay:
    http://www.amazon.com/Relay-Harness-...pr_product_top
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    It not the voltage that triggers its the mA. I think if you have a lower voltage you need to use a relay for that voltage and then use that relay to trigger the 12v relay. Like a 5v relay that triggers a 12v relay. Hope this helps SNO
    Sep 2012
    Germany - Munich
    Why do you need this info?
    You should try to get the Datasheet.
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    Just checked a few supplys...5v 9.5v and 12v...only the 12v worked...tested this on a std auomotive 12v relay...sno is dead right
    Raw Wave
    Nov 2009
    Of course Sno is right. Geez!
    Implicit in Sno's reply is that you match the relay's nominal or rated coil voltage to the voltage you are using - eg, 12V if 12V, 5V if 5V, and any voltage if an Open Collector aka GND signal.
    IOW you do not use 5V to turn on a 12V relay because - even if it does - it will not have its full contact force and hence be prone to (1) fire or (2) open circuits on bumps or if hot etc.
    Nov 2011
    What i a good way to operate a 12v relay from a lesser voltage source...say 1.8v,3vor 5v is the a common tidy way to do this?....ive often thought of this.
    Nov 2009
    Keswick,On Canada
    I would use something like this cheap 5v relay board put my 12v+ to common and NO 12v+ going to the 12v relay pin 86 SNO
    Sep 2012
    Germany - Munich
    you never said, what you want operate with this low voltage. and where the voltage comes from?
    but one thing, be carefull because of the selfinduction.
    Nov 2011
    Ive got a few of those in my ebay watch list...very cheap!!! Any ideas on 3v or under?
    Harryberlin what is selfinduction?
    Raw Wave
    Nov 2009
    Quote Originally Posted by camo.b View Post
    What is a good way to operate a 12v relay from a lesser voltage source...say 1.8v,3vor 5v is the a common tidy way to do this?....ive often thought of this.
    Thru a buffer...
    Usually Open Collector - ie, they turn on a device (transistor, FET etc) that connects the output to 0V aka GND. As long as it can handle the relay's coil current (say up to 250mA for typical automotive 30A relays) then it can turn on any voltage relay. (As before, output to relay coil 85 and other end 86 to whatever +V it uses.)
    Whatever output (1.8V etc) must be able to turn on a transistor etc.
  1. Quick Voltage Question
    By Ryven in forum CNX-P2140
    Last Post: 07-08-2011, 04:10 PM
  2. LCD Voltage Question
    By piersuk in forum LCD/Display
    Last Post: 08-31-2010, 12:47 AM
  3. Replies: 25
    Last Post: 02-16-2010, 02:32 AM
  4. quick question about dc voltage
    By cdm in forum Power Supplies
    Last Post: 03-05-2004, 04:19 AM
  5. tm701 voltage question
    By h_2_o in forum LCD/Display
    Last Post: 06-19-2003, 02:54 AM
