Results 1 to 5 of 5
Thread: finished!
    Sep 2002
    Worcester, MA
    finished!
    pictures here
    all pictures here
    thats a temp solution for powering lcd, its going in opus once i figure out which wire is ground and stuff. temp solution for amp switch too, waiting for remote turn on cable from kris.
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Glad to see you're finished. (for now. there is always more you can do... )
    I don't think the way you ran your main power is good like that...over the engine...
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    is it just me or does everyone have the same fosgate punch amp ?
    anyway yes theres always more you can do such as bondoing/fiberglassing the screen smoothly in. what is your temp solution to powering the xenarc? If you wanna use your power supply ot power it just get a female 4-pin
    (yellow) 12v+
    (black) ground
    (black) ground
    (red) 5v+
    and viola, your good.
    Mine needs to be updated.
    Sep 2002
    Worcester, MA
    it doesnt go directly over the engine, the picture is a little deciving. it comes out of a premade passthrew the firewall, which made things SO much easier. Then it goes right over the air intake to the battery. I am gonna reroute them so they go along the side of the engine.
    I like my amp, its the 700x. i got it for 199 on ebay. ~1000 watts RMS .
    I want to fiberglass the screen in, but first i need to make it flush. That is gonna come later, ive spent enough on it for now. I need to shave about 3-4mm off of each side of the case, and then it should be able to slide back. The temp solution for the xenarc is having it run off of the inverter. I need to hack off the brick at the end and wire it up to the opus, but i need to figure out a way to find which side is power and which is ground, i already got the 4pin cable wired up and ready to be plugged in .
    and like you said, its only done for now. I need to buy gps and obdII connector, dlink fm adapter, make a usb hub in the console....
    the list goes on and on.
    I just got back from 5 hours of driving around testing it out. ran like a champ, absolutly no problems. I'll be writing up a thread in the show off your projects forum tomorrow, i just wanted to share now
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Quote Originally Posted by samc
    well, at least everyone doesnt have the rockford fosgate "rocket-ship" amp that was uber-popular about 5 years ago...
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
