With 3 12's in the back, I wouldn't bother with rear fill, and I'd disconnect the factory rear fill speakers. It's more than likely going to be overpowered by the subs, but I guess it comes down to how you set it all up.
How are you powering the new 5.25 splits up the front? Off an amp?
LinkBack URL
About LinkBacks
the JL audio FAQ website has great information on sub enclosures including push-pull isobaric enclosures. But, do you really need an iso box? Are you low on space? You can always mount a sub upside down. I'm not sure how much volume you gain in the box when you do this, but you'll want to figure that into your calculations for box size. I saw a sweet fiberglass enclosure for those subs, buth there were three... Two mounted standard and one inverted to see the basket...
