Results 11 to 20 of 26
Thread: AC cooled Carputer?
  1. #11
    Jan 2003
    Ruston, LA
    Quote Originally Posted by guitar333
    Get to work frodo!
    you do it, I'm much too busy
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    Variable Bitrate telekineticfool's Avatar
    Mar 2003
    AZ
    Quote Originally Posted by samc
    wow 120+ degrees? I think I'd have more bodily cooling problems then my carputer. If its really that hot where you live try the trunk with routed AC. And some very strong fans.
    I've actually going to have it mounted behind the drivers seat...but my car has ultradark tint and a sunshade.
    Phoenix summers aren't really that bad, everything is airconditioned...the only time you're outside is to go to and from the car. It's hot enough that you don't even go swimming after 10am or before 5pm in the really hot months....
    MP3 MR2 (click here for details)
    Hardware: EPIA M10000, 512Meg Ram, 5.6"TFT, Opus 150watt DC-DC PSU
    Software: Windows 2000, Media Engine 2.0
  3. #13
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    AC cooled...yes mine is.
  4. #14
    Low Bitrate Pogi's Avatar
    Sep 2003
    West Palm Beach, Florida, United States
    Condisation would be a problem, but what about that Silca Gell packs, like the ones you find in ur new shoes?
  5. #15
    Aug 2003
    HOME CHICAGO, NOW IN Greensboro
    An effective way would be is to move the intake of the ac over the carputer......
    It can easly be incorporated by taking a flexible hose from your carputer and insert it in the intake duct of the hvac system.......
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
  6. #16
    Sep 2003
    ehhh, I dont think the AC would like sucking in that heat, though if it where on circulate the Ambiant Air would Cool down, but sucking in heat constantly I dont think it would be healthy.
  7. #17
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    Water cool it. Except use metal water lines instead of pvc tube. That's so it's not greatly affected by external temps. Drill two holes under your car and fit the radiator under the body. That way it super cools while your driving and stays in the shade with open air to pass. It should remain cool, as long as you have it far from your exhast pipe, transmission, and anything else that heats up under there. Under passanger seats should be ok.
    Mg.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  8. #18
    Aug 2003
    Quote Originally Posted by Pogi
    And I assume that you have some experience and or technical knowledge on HVAC's
    ALIBABA - I30 99
    Nemiah M10000, C134
  9. #19
    Mar 2003
    AZ
    Quote Originally Posted by Magnezium
    If you use metal lines, it will match the external temperatures quicker...to isolate, you'd want an insulater...very much like PVC pipe. Metal lines would be HORRIBLE for keeping the water from being "greatly affected by external temps."...in fact, I'm not sure if there are any materials that would be worse suited for that purpose....maybe something radioactive
    edit cuz i forgot to say it: good idea though, you totally made me evaluate my undercarriage...not sure I have the clearance in my car to stick anything under it :-)
  10. #20
    Maximum Bitrate SjLucky's Avatar
    Jul 2003
    Hattiesburg, Mississippi
    well oil coolers and tranny coolers use metal lines... What about that pipe crap you get for your pipes in the winter?
    Oh yeah to hell with goin under the car mount that sucker right up infront of your radiator (just like The Big Three do with their tranny coolers) that way you can run right along side of the car and not worry about transvered heat from those hot parts you stole.. I mean those parts that generate heat
    Quote Originally Posted by menudude View Post
    thank you all for your help minus the useless post by sjlucky...
