Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: AC cooled Carputer?
  1. #21
    Maximum Bitrate fluffy2097's Avatar
    Jul 2003
    Fremont, CA
    I don't think that running your AC over a computer would have too much problem with condensation. AC's are also dehumidifiers, the air blowing out of them is pretty dry, I've never tried though, so I could be wrong.
    I'd never personally use a water-cooling system in a desktop computer, let alone a car. Water cooling systems have a nasty habit of blowing up and spilling water all over your computers innards. I wouldn't trust the connections from the tubing to the water blocks in a high vibration environment. It seems like a recipe for disaster that can easily be avoided by keeping your design simple.
    A digital mind lost in an analog world.
    Learn to ask smart questions!
    http://www.catb.org/~esr/faqs/smart-questions.html
    My car PC: The Lost Cause!
  2. #22
  3. #23
    Low Bitrate Pogi's Avatar
    Sep 2003
    West Palm Beach, Florida, United States
    so AC would probly be the way to go, if using a Real powerfull machine and an inverter. Like have a carputer under the Drivers Seat, and the inverter under the passanger seat. I have Vents under my seats for the backseats. and I could tap into those for AC cooling! sounds good
  4. #24
    Constant Bitrate Magnezium's Avatar
    Oct 2003
    Los Angeles, CA
    I have my Transmission cooller also mounted infront of my radiator. It's works GREAT! That's a good idea to do it like that. My only concern would be engine heat. It heats up quite a bit under the hood. At times when the car isn't in motion (Stop lights, or parking idle), the radiator would actually be heating up. If anything, maybe ceramic coating metal lines. telekineticfool has a point, but ceramic coating might help.
    Mg.
    Just your friendly neighborhood computer specialist.
    2002 Pontiac Trans Am WS.6
    Silver/Black
    Looks like new... Wanna know why they call me "Crash"?
  5. #25
    Aug 2003
    HOME CHICAGO, NOW IN Greensboro
    Gentlemen,
    Lets cut the confusion
    The fact remains that if you take the AC output it will be almost dry however it may shock the components ...... The right way is to pull air over the chips.....
    Transmission oil temp and engine coolant is much higher than the ambient and hence will cool those two as the delta will be high however, it will not work for temp which are almost close to ambient.....
    And if there were any problems inhailing air passed over electronic chips, it would not be allowed in areas where people move around w/o any protective gear
    So chill out.....
    ALIBABA - I30 99
    Nemiah M10000, C134
    DVD, 40Gig, 256MB DDR
    GPS, OBD 2, Reverse Cam
    Mute on stereo w I300 car kit
    Liliput 7in w usb touch screen
    Direct connect with BOSE-CD changer
  6. #26
    Sep 2003
    Quote Originally Posted by skassama
    Gentlemen,
    So chill out.....
    I still dont get that?????
