Results 1 to 10 of 12
Thread: My Custom Plexi Case
    Low Bitrate SonicCobra03's Avatar
    Sep 2003
    STL
    I'm not quite done yet, but here is what I have so far. I've still got some cleaning up to do, but it's getting there.
    Sep 2003
    STL
    Almost forgot, Here is what it is going in:
    Registered User SWYZ721's Avatar
    May 2003
    My boy's got a Snake what's yours runnin in the 1/4?
    Sep 2003
    STL
    Quote Originally Posted by SWYZ721
    1/4 - 12.2 seconds with a 2.2 60'
    The '03s are torque monsters with the peak torque at 3500 rpms. Hard as hell to launch, even with Nitto Dr's. I've got suspension work coming, IRS bushing, sub-frame connectors, coils, DR loop, getting put on next week. Hopefully I can put the power to the ground. On my last video with the 12.2 run, I'm spinning all through first and wheel hoppin through second. I'm still trapping 119, but I should be mid to high 11's with the power I've got at the wheels. I've been thinking about at a small dry shot also. The supercharger heats things up so much that most '03 cobras are netting 60rwhp with just a 30 shot. Next spring I'm probably going with a KB twin screw . With my current mods and a KB @15psi = 550rwhp with a conservative tune.
    Newbie BBrinks's Avatar
    Oct 2003
    Your Cobra sucks. Take my GT and I'll take that piece of crap off your hands.
    J/K. I haven't posted that much, but I've been going to this site for about 2 years now, and it's great to see another Mustang on the boards. How do you plan on mounting the screen? I'm going to do mine over the winter when mine's in storage, but I haven't decided where I'm going to mount the screen yet.
    Awesome Cobra, BTW.
    Sep 2003
    STL
    LOL, my little sister has a 2002 GT. Thanks for the compliments. Ok, enough joking around. I plan on removing the radio bezel and then fabing a sheet metal brace that is attached at the AC panel screws and then run up above the vents and then put the bezel back on. I have a bracket like that now for my palm autotap. I just attached to the AC panel screws and bezel fits over it. If that doesn't work, then well....., its going to work! Hopefully. I'll scrap the project before I cut up my car, I don't want to do anything that is permenant.
    Car will be garaged all winter, so by the time my screen gets delivered I won't be able to use it until spring.
    Maximum Bitrate jzgt's Avatar
    Mar 2002
    Nice car! I have a Mustang also...
    It's a 1987 GT Convertible with a 306, TFS twisted wedge heads - stage 2 port by Bennett, E-303 cam, 1.6 Rockers, Pro-M 77mm MAF, GT-40 Intake, 70mm Throttle Body and EGR spacer, Paxton 6 lb. blower with the VR-4 upgrade (Yeah, I know it's old, but it works), and a NOS 5115 nitrous kit which I haven't used yet. I ran it at the track but with the combination of 2.73 gears (I know, I know ) and stock pony wheels, it only ran 13.43 @ 115 MPH. I haven't had it tuned yet...and I'm certain it needs to be leaned out down low and possibly fattened up - up top. My best 60' that day was a horrible 2.467 (It was either bog or spin wildly).
    Those new Cobras are awesome. I was at Larocca's Performance with my friend while he was getting his car tuned and Andrew (one of the tuners) was saying that you can easily get 500 hp out of those cars with a pulley and a chip (tune). Nice to have a warranty, too
    I'll see if I can dig up some pictures of my car.
    Good to see other Mustang owners here!
    - Jeff
    Sep 2003
    STL
    Nice ride. You need to work on those 60' times though. Your trap speed is doing good enough for low to mid 12's. As far as the new Cobras, 500rwhp is tough to get with the stock eaton, even with a upper and lower pulley change. Once you start going past 14lbs of boost the only thing that goes up is Torque and the heat soak.
    Apten Performance here in StL can port the eaton out for about another 40rwhp which will get me over the 500 mark , next goal is 600rwhp, but I'll have to go with a twin screw blower for that. As far as the bottom end goes, it's all forged coming from the factory , It can hold 800rwhp easily.
    Once over the 500 mark though alot of things have to be upgrade. Injectors, MAF, etc. The main thing though is the half shafts, lol. They barely hold up now as it is.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    nice let me guess you used methleye chloride to put your case together? And ..12.2? DAMM.
    Mine needs to be updated.
    Sep 2003
    STL
    Quote Originally Posted by samc
    Actually I just used Goop for plastics. I stood on the box after I was done and it held up so I think it will be ok . We'll just have to see how it reacts to heat. Oh, and the 12.2 isn't that great considering my mods. Stock '03 Cobra's are in the 12.6-13.0 range. I just can't get the extra torque to the ground.
