Results 1 to 3 of 3
Thread: Network Problem
    Jun 2003
    Network Problem
    Hi,
    Im having problems trying to transfer files from my home computer to the car computer, using a network card.
    The network card from my epia works fine when its at home, hooked to a normal atx power supply, but when i use a opus as power supply on a car its stops working..
    I think it might be a ground issue, is it possible??
    Tks,
    Bruno
    Tks
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    how do you know it stops working?
    how have you tested it?
    the only thing you change is the power supply?
    everything else works?
    how much power does your atx supply put out?
    how much does the opus put out?
    maybe research through here also...
    http://forums.viaarena.com/
    Jun 2003
    Quote Originally Posted by DodgeCummins
    I just tested with an atx power supply and with my opus. When i use the opus the network card doesnt work, but with a standart power supply it woks perfectly
    Yes...
    Everything, exept the network card
    350 Watts
    90watts, but im using a 2.5 laptop hard disk and a slim cdrom only.
    Thanks, i will try...
    http://forums.viaarena.com/[/QUOTE]
    Tks
  1. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 12:09 PM
  2. need help with home network
    By meyer64 in forum Off Topic
    Last Post: 06-04-2003, 02:22 PM
  3. Annoying problem
    By c-dawg in forum General Hardware Discussion
    Last Post: 07-22-2002, 09:19 PM
  4. Need win98se full version help for a problem!!!!
    By jssaggie in forum Software & Software Development
    Last Post: 12-04-2001, 03:08 PM
  5. Sound card and network card
    By Matthew_sl in forum Software & Software Development
    Last Post: 01-31-2001, 04:29 PM
