Results 1 to 10 of 12
Thread: Attention Volkswagen MK4 owners
    Maximum Bitrate BoraXP's Avatar
    Jul 2003
    anyone else have a problem keeping the computer on with a volkswagen?
    when the my car hasnt been on for a while, the fans in the engine compartment run and when they turn off i get a power spike (or something) that shuts down my computer. Im not using an opus and i definatley need a new battery.
    any of you out there experience anything like this?
    Aug 2003
    Orange County, NY
    Quote Originally Posted by BoraXP
    Do you mean the engine cooling fans keep running to cool the motor after it is shut off, then once the fans shut off, your carputer dies?
    Jul 2003
    Quote Originally Posted by jasonsp6
    no when i turn it on
    fans run
    Aug 2003
    Orange County, NY
    fans run
    Try to better explain this.... do you have a problem with the cooling fans coming on when they are not supposed to?.... After we figure that out, we can work on the carputer problems.
    Jul 2003
    maybe its not a fan, maybe its a pump, i donno. All i want to know is if any other mk4 owners have problems with their stock battery giving enough juice within the first 60 to 120 seconds of the car being on after a long (usually 4-6 hours) of being off
    Aug 2003
    Orange County, NY
    Ok, thanks for clarifying that...
    I have a 02' MKIV and haven't had that problem with the stock battery and stock electronics in the car.
    On the other hand, with testing my computer and related hardware, I have run into problems with my stock battery rapidly losing capacity in the cold when it would otherwise be fine in warmer weather.
    I installed a Optima Deep Cycle Battery and it is holding up better for me. Only disadvantage is that you need to slightly modify the battery tray to hold it. (Atleast I did in my GTI, other models may vary)
    Maximum Bitrate none's Avatar
    Sep 2003
    The fact that you are not using an Opus is interesting by itself (not,) but considering that there are a dozen or more possible alternatives, information about what PSU you ARE using would be far more helpful.
    May 2003
    MA
    Have a similar problem in my MKIV, running the PW-70A w/ ITPS. Are you running of the AUX in the trunk or did you hard wire to the battery? I stuck a volt meter in the AUX, and found that it a very crappy +12 Volt line.... ie everything up front in the car gets power prior to the AUX supply, so I'm planning on adding a extra battery (12v .7Ah with a diode) under the hood and hardwire the power to the computer...
    This will get done when the temp in NewEngland goes above 20°F, in other words it's to fu**ing cold so plastic breakes when working on the car.
    VWTronics
    Jul 2003
    i have a 0 guage running to the back powering my amp and computer
    i figured it was the battery becuase on version one of my setup it used to run fine
    then i took the car to the dealership a few times for some work and they drained the crap out if the battery
    ive tried recharging it but it wont hold a good charge
    im thinking of buying an optima yellow or red top
    or maybe even doin a second battery with an isolator
    i have a friend who just bought a new battery that weighs less than a pound and has a foot print of about 12*9*3
    so yeah
    thanks for the help even with the unclairity
    and i dont have an opus becuase i dont want to spend 190 when i got my 70a and a mucha for under 80
    even though i can throw a rock and hit opus's windows from my house
    Sep 2003
    I don't care why, I just asked which. Opus isn't the only solution on the planet.
    The real root of your problem is that the PW-70a isn't really suitable for automotive use. I would be willing to bet that the unregulated 12v is dipping and spiking all over the place - bad news. You really need a new PSU with a regulated 12v line - and I don't mean a simple linear regulator like on the ITPS, this will only make your problem worse.
    A new battery might be an acceptable patch-up solution, but it isn't addressing the root of the problem. When the shinyness of the new battery is gone, your problem may return.
  1. Attention SV24 owners.....
    By WakeAndSno in forum General Hardware Discussion
    Last Post: 11-26-2001, 08:45 AM
