Results 1 to 10 of 14
Thread: Custom Case takes forever!
    Dec 2000
    Orlando FL (UCF!!)
    Red face Custom Case takes forever!
    I have started my plexi case and so far I have great results. WHat ways can I cut the plexi? I dont want to use a saw because i dont want to crack it and my dremel gets tired after cutting for a while. It heats up and I have to let it cool for like hours.
    This project is taking forever!
    Has anyone had problems like this?
    .:@mÖ§pê®ë:.winamp.win98.pentiumII.10gig
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    Post
    Dunno, mine took a few days too.
    Mar 2000
    Washington DC
    Post
    Do you have a variable speed dremel?
    I set my dremel on one of the lower settings (either 1 or 2) and I don't have to worry about the plastic melting. It takes a bit longer then if I use 4 or 5 but the dremel doesn't heat up.
    mc
    mc is offline
    Aug 2000
    Orlando,FL
    Angry
    <font face="Verdana, Arial" size="2">Originally posted by Arby:
    Dunno, mine took a few days too.</font>
    why do you always respond with a smart *** reply
    Music is the language, love is the message.
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Mine took three weeks to make.
    Aaron Cake
    Player: Cyrix 200, 32MB RAM, 10.2Gig Quantum HD, Onboard EtherNet/Sound/Video, Custom Lexan Case, Arise DC-DC, Win95 Kernal w/Custom Player
    Car: '86 Mazda RX-7 w/Basic Performance Upgrades
    Mar 2000
    Portland, OR , USA
    Post
    <font face="Verdana, Arial" size="2">I dont want to use a saw because i dont want to crack it </font>
    You can easily cut Plexi with a saw. Just buy a blade with small, fine teeth. You have to cut slowly, but you can go faster than using a Dremel!
    I built a Wet/Dry filter system for my 150gal tank out of plexi and I cut it with a fine tooth saw blade. Worked fine.
    I'm referring to a powered rotary saw here, NOT a hand saw. I don't know if a hand saw would work very well.
    [This message has been edited by Craig Chatterton (edited 01-19-2001).]
    Sep 1999
    Yarmouth NS, Canada
    Post
    Your dremel should run ok for quite a while without over heating. I'd check the way you are holding it. There are vents on the side of the dremel and you should NOT be covering these with your hand and blocking air flow. Its a quick way to ruin the brushes in the motor or overheat it. And like others said, cut at a low speed and dont force the wheel through, just let it do its thing. It can take quite a while to cut anything bit with a dremel but it does a nice job if you take your time.
    MP3 Cavalier - http://www.mp3cavalier.com
    MP3 Grand Prix - http://www.mp3gp.com
    Dec 2000
    Orlando FL (UCF!!)
    Red face
    thanx people for all you input, I finally got all my pieces cut perfect! I just used the dremel slowly and blew in the holes to keep it cool. The dremel sander works great too for fnishing the edges!
    More to come....
    . ïGi±@£aÑaLÖg:.
    Jan 2000
    Alpharetta, GA
    Post
    What thickness of Plexi is everybody using? The Lowe's and Home Depot near me only have 1/8"
    JohnRam
    Jan 2001
    Irvine, CA, USA
    Cool
    When I have had to cut plexiglas, I set it on a flat surface, and put a straight edge over where I need to cut. I score it repeatedly with a razor, and after about ten good swipes, it cracks along the line when I bend it.
    I have tried using a rotozip to cut plexiglas, but have had bad results. When I go too fast, it makes a jagged cut, and when I go too slow, it melts it.
  1. '93 Opel Vectra A - Custom Dash & Custom Case
    By zvi in forum Show off your project
    Last Post: 10-18-2005, 08:36 AM
  2. custom making a case
    By ares in forum General Hardware Discussion
    Last Post: 03-12-2003, 09:38 PM
  3. Need your input on custom case
    By Adam F in forum General Hardware Discussion
    Last Post: 09-24-2002, 10:42 PM
  4. Need A Custom Metal Case?
    By brentp4 in forum General Hardware Discussion
    Last Post: 11-12-2001, 10:19 PM
  5. digital out on the soundblaster live card and makeing a custom case
    By donalson in forum General Hardware Discussion
    Last Post: 11-27-2000, 06:17 PM
