Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Question On Boot Times
  1. #11
    Feb 2004
    1:dont go epai
    2:win98 i think if you have a fast prcessor and a good mobo if you disable all the checking ie. boot right to hdd w/o a: and the memtest you can prolly get around 20 seconds
  2. #12
    May 2005
    definately a BIOs problem if your OS loads pretty fast. Try checking some of your settings...I had a similar problem because 1) i didnt have my hardware settings saved and it had to check them every time....and 2) there is a quickboot and a normal boot do a quickboot and it will go much faster.
  3. #13
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by crosseye
    7 seconds is unheard of. I have never heard of a PC booting that fast... you can barely get through the Motherboard's POST test in that time.
    There's a guy who claims to have 7 second resume from suspend.
  4. #14
    Jun 2004
    The North, Manchester
    mines about 25 from hibernation. 512MB RAM though so thinking after CF upgrade might go over to EWF now most things have been straightened out
  5. #15
    Maximum Bitrate zPilott's Avatar
    Jul 2004
    Austin
    I would try hooking up the staring of the car to your alarm remote so when you unlock the car it starts up. That would give you at least a second or two more time.
    |V1 Virtual Display|
    Hard work often pays off over time, laziness always pays off right now.
  6. #16
    May 2005
    Austin, TX
    Check out Soekris Engineering. They make fully small scale 486/586 machines that run linux. They have no monitor output, you just use hyperterm over a serial connection (dumb terminal). They have no hard drive, instead you install the OS on a flash card, just like a digital camera uses. These things can supposedly be runng in less than ten seconds. This would be great for ignition work...
    I'm working on two different projects that will use the Net4521, but I haven't received them yet...
    cent
  7. #17
    Low Bitrate madmartigan's Avatar
    May 2005
    Canada
    I think when I finally get mine to the installation phase I will use win2k pro.
  8. #18
    Mar 2004
    California
    Even better, use an inexpensive fingerprint reader to login, and again to do ignition. Sure beats having to remember PINs, and it gives you the ability to grant access to others to the car. I was tempted to use one in my rig, but since I have manual transmission, I shyed away from it.
    Kevin
    Audi A4 Carputer, 80% setup.
  9. #19
    I've got no answer! Question's Avatar
    Jan 2001
    Austin, TX
    14 seconds from hibernating to playing music. I also have my alarm's aux output set to trigger the pc so that if I hold it down for 3 seconds, it turns on. When I'm walking to the car, I turn it on, and it's timed perfectly.
    1999 Plymouth Voyager (That's right, big-pimpin' in a minivan.)
    PC built into console
    worklog with pics: http://www.mp3car.com/vbulletin/worklogs/46359-1999-plymouth-voyager-computer-in-console-between-seats.html
    Some of my music: http://www.myspace.com/markquestion
  10. #20
    Jul 2004
    Austin
    Quote Originally Posted by Question
    That is kinda what I want it to do, but I just want it to start when I unlock the car. It would be pretty easy if I had an aftermarket alarm, but I don't. I was a little bit worried about mucking around with the electronics, but I think I have a good idea of how to do it now, when I get the time.
    I am also at about 15 seconds from hibernating to music, and suspend is only 5 seconds or so.
    |V1 Virtual Display|
  1. Faster Linux boot times
    By hijinks21 in forum Software & Software Development
    Last Post: 12-13-2003, 12:40 AM
  2. I'll show you boot times...
    By gork in forum Software & Software Development
    Last Post: 09-29-2003, 07:53 PM
  3. boot times
    By pinkysqueaks in forum General MP3Car Discussion
    Last Post: 08-31-2001, 06:30 PM
  4. Decreasing boot times
    By schrodos in forum Software & Software Development
    Last Post: 02-07-2001, 05:42 PM
  5. boot times for mp3 players
    By alany in forum General Hardware Discussion
    Last Post: 12-16-1999, 12:09 AM
