Just bought a 2004 Pontiac Grand Prix. Double din and very easy dash to mod.Originally Posted by mutilator
double din headunits.
just wondered how many of you guys have double din spaces in cars as standard,
if you could just post the make/model/year of your vehical, that would be cool
thanks,
Tom
Aultl
[====---] - 65% complete
Status: Configuring Software
VIA Epia 800mhz, 256Mb ram, 10Gb HD
Quote of the Month: "I see the problem, [The RAID controller] is trying to rebuild the array with good data from a failed drive." -- HP Support
[QUOTE=mutilator]double din headunits.
thanks,
Tom[/QUOTE
Hyundai Sonata 2004 has a double din space. Took out the factory system and installed a single din head unit so I now have room for a single din pull out screen!
My 2001 Xterra had a double din radio/cd changed. Below it was a single din sized space with an ashtray and cigarette lighter. Replaced ashtray and lighter with a single din radio, and existing double-din space was used for screen / computer.
VIA EPIA M10000 | 7" Lilliput Touch VGA | PW70 | 256 Meg RAM | 20 Gig 2.5" drive
Dual Battery with Optima Yellowtop | Hellroaring Battery Isolater
ICOM 2720A| Delorme Earthmate GPS | Tiny Track APRS
Survives Crank
My 1997 Mitsubishi Carisma has a double-din opening. It had a single-din stereo and a single-din "cubby hole" which I have taken out and replaced with a 7" touchscreen
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
the 4th generation maximas (95-99) have 3 dins! radio was double din, then the cubby is another DIN.
[ 5-spd 1996 M A X i M A SE ]
Basically most/all Toyotas cars (since 80) have double din openning.
There are some combination for that double din
Single Din Radio + Single Din EQ
Single Din Radio + Storage pocket for Tape, CD, or other junk
Double Din Radio.
And they all have mounting bracket so ISO standard aftermarket radio fix nicely with that bracket.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Mitsubishi FTO 96
Got stereo and the whole of my carpc in it.
2001 Toyota Sequoia, Double Din.Originally Posted by mutilator
ok, thanks guys.
i got an idea....
