Results 1 to 10 of 11
Thread: XP Embedded flash boot?
    Feb 2004
    I didnt know where to go to post this since there doesnt seem to be a area for operating systems for the carputers.. so I put it in General
    I have read things here and there that it is possible to boot XP embedded from Flash ram/rom? Anyone done this yet?
    I am fairly computer savy, wouldnt you have to set it in the bios? I'll have to check the bios on my computer at home when I get there to see if there is an option for it.. I am planning on using the EPIA 1000 mobo (I know thats not the exact model but I forgot what the exact model is)
    Jun 2003
    Memphis - TN
    get a CF to IDE connector, put it on a flash card. Ive done it. Seems slow to me.
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    Custommx3, you'd recommend a hard disk over a flash drive anytime?
    -Mars
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Things that could make flash better:
    Works better in enviornments below freezing.
    Consumes alot less power.
    Smaller although usually not denser in terms of storage.
    Quote Originally Posted by Marsupial
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Feb 2004
    Montreal
    if you have a choice between a 20 gig extended range HDD (-20 to 80 celsius) and a setup including a 2 gig flash IDE drive... which would you choose?
    -Mars
    Feb 2004
    Which manufacturers make extended temperature HDDs? Where can you purchase them?
    Feb 2004
    Montreal
    http://www.hgst.com/portal/site/hgst...a0466460e4f0a0
    where can we buy? dunno, but will find out when I decide to buy all components.
    -Mars
    Variable Bitrate nadir_s's Avatar
    Oct 2002
    San Jose, CA
    a 2 gig Flash drive would cost way too much $$$$$$$$$
    [ 5-spd 1996 M A X i M A SE ]
    Jan 2004
    Quote Originally Posted by Shredder
    It's a lot easier to boot really fast in Linux. In fact there are even replacement Bios you can get for the EPIA's that will make it boot very fast. The Empeg can boot up linux in about 3 seconds and it only runs a 233 Mhz processor. It does this by keeping the linux kernel in Flash memory and only mounting the hard drives read-only. Mounting the hard drives read-only also allievaties the need for cheesy shutdown controllers since turning off the machine without properly shutting it down is no problem.
    Feb 2004
    Quote Originally Posted by Custommx3
    What is your boot time? It seems like it would be a ton faster to me.. maybe its an IDE limitation?
  1. PowerMate on Windows XP Embedded
    By JasonSurratt in forum Input Devices
    Last Post: 01-14-2004, 12:06 PM
  2. XP embedded progress
    By All4Norway in forum Software & Software Development
    Last Post: 01-13-2004, 11:37 PM
  3. Using ME With XP Embedded
    By Dr Frag in forum ME Archive
    Last Post: 11-19-2003, 02:16 AM
  4. Via and XP Embedded
    By orangewhip in forum General Hardware Discussion
    Last Post: 05-26-2003, 05:48 PM
  5. boot times with XP
    By Alives in forum General Hardware Discussion
    Last Post: 11-15-2001, 01:42 PM
