Results 1 to 6 of 6
Thread: Any partial/completed '00-'04 Cavalier installs?
    Mar 2004
    Wanting to add PC to my '04 Cavalier. The interior is kinda tight so looking to see what others have done to get an idea. Suggestions/stories/avoidences please.
    Maximum Bitrate owenjh's Avatar
    Nov 2003
    NC
    Yea, I got a partial install going on monitor just got installed its just a flipout 5 incher for now, plan to get a better one later on. Waiting on parts right now. Your going to run into alot of problems. I have a 00 cavalier wish it was a 2.4 '99 with some better options instead of a base model 2.2 '00 anyhows. Problems I ran into so far (except no money) are:
    Problem:
    No ACC wire for stereo
    Solution:
    1) Use a mini fuse tap to get ACC from windshield wiper
    2) get into the ignition coil and find which is the ACC line
    Problem:
    Space for stereo is very small, and the wires at the back of the unit still wouldn't fit because of the heatercore(?) or something like that.
    Solution:
    Had to cut away plastic for unit to fit in and then take the guts of the monitor out and rig it to stay on the installation kit
    Depending on what sound package you have you will probably run into some problems, you might end up paying $70 for a chimer if you can't live with out them.
    There are some nice spaces where you can mount your PC if you look, not sure if yours will be the same but I have space in the trunk behind the carpet, if you have 2dr you have a nice space under the plastic where the pasenger sits there is a styre foam block in there, am not sure of size but plan to take it out someday and measure. When you take your door panels off, you probably want to do everything your going to do all at once because it is a pain.
    Will add more stuff as I remember it. Can't wait to finish the install tho
    CarComputer Status: New Car & Broken (Motherboard Fried)
    Owen JH | My Linux Blog | The Tech Fellows
    Mar 2004
    you have any pictures?
    Nov 2003
    NC
    Will have some when I get around to it. None of the install as of yet, but I still need to take the dash of again to put some wiring in for switches and sensors
    Variable Bitrate Cherub211's Avatar
    Feb 2004
    Chandler, AZ
    $5 says you can get good information from here
    http://www.j-body.org/
    FLAC mp3z24's Avatar
    Apr 2001
    Chicago Suburbs
    Quote Originally Posted by Cherub211
    i have $100 that says you wont find crap at that site, and further more, you will be so ****ed off at the incredible bickering, name calling, flaming, and general ***-hattedness of the forum that you will wonder why you ever ventured in there looking for anything resembling a coherent thought.
    or at least that is my take on j-body... and yes, i am....er, was a member there.
    ~mike
    Single Member of the "1000 Post and No MP3 Car" Club
    PROJECT ON INDEFINATE HOLD... BOUGHT A HOUSE
    2000 Cavalier Z24 [###-------] Only 30% Done ... Still
